OBD-I code
Old Jul 21, 2010 | 07:37 PM
96ford250's Avatar
96ford250
OBD-I code
I got a code reader for my 96 f250 351w 5sp 4x4 and i got 542
542 = Fuel pump open, bad ground or always on - - Power / Fuel Pump Circuits.
my question is what does that mean both my pumps work and the only thing i can think of is that when i was changing out my crapped out turn signal arm i turned the key forward with out the tank selector pluged in to make sure the arm worked before i put it all back together and the fuel gauge went to over full would that throw that code or am i way off base?
Old Jul 21, 2010 | 08:20 PM
subford's Avatar
subford
That would do it.
Old Jul 22, 2010 | 05:52 PM
96ford250's Avatar
96ford250
cool does the code just go away i cant delete them with my scaner or do i jus take the neg off the battery
Old Jul 22, 2010 | 06:07 PM
subford's Avatar
subford
Never take the Neg battery cable off to clear the codes unless you replace a sensor as it will set another code and then your computer will have to learn all over again.
To clear the codes ground the STI wire and turn on the key, when the MIL (CEL) starts to flash remove the ground from the STI wire and the codes will be gone.
Old Jul 22, 2010 | 06:31 PM
96ford250's Avatar
96ford250
cool thanks
BURNSTOUGHFORD
29
Oct 15, 2013 12:33 PM
Cdy1
1978 - 1996 Big Bronco
Sep 23, 2009 08:17 PM
CalvaryMusicMan
3.8 & 4.2L V6
May 11, 2007 09:04 PM
twotonestepside
1983 - 2012 Ranger & B-Series
Feb 28, 2006 08:40 PM
