A couple electrical question?
Old Jul 20, 2010 | 11:12 PM
Rlbol's Avatar
Rlbol
1) has anyone installed heated front seats in a non heated seat excursion? I installed them but the plugs are different. Original one being 3 wire newer seats being 5 wire and I assume the passenger side will have no wiring since it is a manual adjust seat?
2) I read on here some where about upgrading the factory wiring to the head lights. I do not have the fog lights but plan on installing a factory set as well. I can't locate the wiring up grade under the search. If anyone has the info or links it would be greatly appreciated!
3) lastly anyone ever install a second battery on a v10? If so what was involved parts wise? Can the factory alternator handle it?
Old Jul 21, 2010 | 12:59 AM
shortboxd's Avatar
shortboxd
can't help with the seats, but here's a couple of links that might help with the lights....
http://www.dieselsite.com/index.asp?...ROD&ProdID=358
S&S Diversified
Old Jul 21, 2010 | 06:25 AM
Rlbol's Avatar
Rlbol
Thank you for the links
Old Jul 21, 2010 | 08:51 PM
fuelman's Avatar
fuelman
Find a place for the battery and ground to the engine the run the positive side to the other battery's positive side done alternator will be fine may charge the original battery slightly better do to not being directly hooked to no.2 but no worries
swcash
1997 - 2003 F150
Oct 25, 2009 05:48 PM
kpriddy
Electrical Systems/Wiring
Dec 24, 2007 11:09 AM
Mallo
Oct 29, 2007 03:56 PM
silly34
Mar 2, 2005 07:30 AM
TBlade
Feb 13, 2002 07:12 PM
