how would i convert to IH tractor motor
Well, you would need a bell adapter to likely a SAE bell so that you can find a transmission to hook up, then you have to figure out a clutch setup to do it. The 1206 motor is a heavy monster for the application, as well as plenty tall.The adapter mounting on the 1206 is the same as a 1266 if I recall, just that the 66 series has a wider frame and center section, so then you find an adapter for a DT466, as they are basically the same motor. (DT466 is also the designation for the tractor motor in the bigger of the 66 series. 06 uses the DT407 or DT361, depending on the size of the tractor.)There is a gentleman that goes by Perky on here that has a Perkins from a Massey in his 79 F250.
Not trying to hijack, but thought I would share something I recently learned. A friend of mine is a diesel mechanic at the local Ford dealership and is quite adapt at modifying and changing things. He knows I have a 1986 F150 with 4.9L and 4 speed OD manual. He teased me recently with the lead... "I have a diesel that will bolt in your truck".
He has acquired a mid 80's bread truck which has a 4 cylinder [M4B?] Cummings engine. The chassis is a Ford van with Ford 4 speed manual transmission [w/o OD]. He ran the VIN and found that the chassis was originally equipped or to be equipped with a 4.9L, so either the bread truck supplier bought and replaced the engine or possibly Ford sold the chassis w/o the engine?? Anyway, if one wanted a diesel in their F150, this describes another way to do it without the driveline conversion headaches.
What he said. A BT 4. They came in quite a few bread trucks but i have never heard of them bing ford. They typically used a GM trans
To the OP. a 1206 enging is pysically the same size as a DT466 as mention earlier. they are monsters and require doghousing the firewall and using a electric fan.
BUT a DT360 ia the same size as a 5.9 cummins(but built better) and would be an easier swap( seen one put in place of a powerstoke in a superduty)
