General Automotive Discussion
Power Steering Coolers
Old Jul 20, 2010 | 10:47 PM
fmc400's Avatar
fmc400
MSEE
When is a power steering cooler necessary, and when can it be omitted? I'm putting my '73 Galaxie back together, and in the process I've removed the defunct A/C components. The issue with that is that the vehicle was originally equipped with a power steering cooler, and unfortunately it was mounted to the A/C compressor (and shaped accordingly).
Instead of fabricating a bracket to accommodate the original cooler or buying a generic new one that I can mount with much more freedom, can I just avoid using it in the first place? My '79 F100 doesn't have a PS cooler, and neither did my LTD. However, both of those vehicles have a later-model pump, while the pump on my Galaxie is older. What do you all think?
Here's a shot of the original cooler:
Here's a shot of the power steering pump:
Thanks for the help.
Old Jul 21, 2010 | 09:06 AM
jimandmandy's Avatar
jimandmandy
That may be the reason later model Ford PS pumps make noise and ultimately fail, something I never had happen on another make. Just a thought.
Jim
Old Jul 21, 2010 | 08:00 PM
Ford_Six's Avatar
Ford_Six
Just run a loop of 3/8" tube across the front of the crossmember and back between the pump and steering box. That'll help keep it cool.
fmc400
Apr 5, 2019 01:51 PM
fmc400
20
Sep 8, 2008 11:40 AM
fmc400
Jun 24, 2008 09:05 PM
fmc400
Apr 27, 2008 04:05 AM
fmc400
13
Apr 24, 2008 05:52 PM
