Engine Bogging 95 F150
Old Jul 20, 2010 | 07:57 PM
95F150MTR's Avatar
95F150MTR
Hey, New to the boards and the ford world but could use your help.
I have a 95 F150 4x4 with the 5.0 in it. When you push on the throttle to accelerate at a light or while driving the engine bogs down. If you hold it anywhere on the throttle , it will bog for about 3-5 seconds and then it will feel like it downshifts, but its actually just starting to run smoothly again.
Anybody else had this problem
Any info would help, check engine light does come on but have had it hooked up to a snap on computer and it cant read it but it does say its running really rich.
TIA
Shawn
Old Jul 20, 2010 | 08:54 PM
Conanski's Avatar
Conanski
Pull the codes yourself and check fuel pressure, it should make and hold 40-45psi under load.
Old Jul 21, 2010 | 12:10 PM
Kemicalburns's Avatar
Kemicalburns
Ford Fuel Injection has instructions for pulling the codes yourself.
when was it tuned up last? like mentioned checked fuel pressure and perhaps change the fuel filter. its located under the driver seat mounted on the inside of the frame rail.
Old Jul 21, 2010 | 07:23 PM
95F150MTR's Avatar
95F150MTR
hey, thanks for the suggestions... I'm gunna work on pulling the codes tonight hopefully... Fuel filter was changed within the last 250km and at the same time plugs/wires...
I'm not thinking fuel pressure would be an issue if its running really rich? to me that would mean its got lots of pressure?
Oh and one other thing it gets terrible fuel mileage.
Old Jul 22, 2010 | 12:05 AM
deve's Avatar
deve
you might want to check to see if you have a clogged cat
Old Jul 22, 2010 | 12:17 PM
Kemicalburns
checking the fuel pressure is important. anything above 45psi is an issue and resulting from a bad FPRegulator. cheaper to test then to replace parts that are not the cause.
Old Jul 22, 2010 | 08:41 PM
95F150MTR's Avatar
95F150MTR
Ok so the codes I got were
KOEO
121
172
KOER
121
172
225
121 seems to be something with the tps sensor but it more talks with the voltage to it than something wrong with the sensor, unless it means the sensors toast.
172 is that its rich, which i already knew, lol
and 225 is something to do with the knock sensor not responding
anyone have any interpretation on those?
TIA!
Old Jul 23, 2010 | 09:05 AM
Conanski's Avatar
Conanski
Ignore the other codes the TPS code is most if not all of your problem. You can test it using data from here.. Ford Fuel Injection Throttle Position Sensor (TPS) you are looking for the proper open and closed voltages as well as a smooth transition through the whole range with no dead spots. If the sensor fails on any of these replace it.
Old Jul 26, 2010 | 11:20 PM
95F150MTR's Avatar
95F150MTR
Well I seem to have made it somewhat worse now. Pulled off the TB to put the new TPS senseor in... all went well, put it back together.
While i was in there I cleaned it all up, but now the throttle wont close all the way. With the new sensor in there, it gives me a code 122, instead of the 121 and the code is on 99% of the time now. Also the truck wont go above 50 with the new sensor in there, but who knows if that has something to do with the throttle not being able to close... ugh!
EDIT: Also getting code 998 now as well. but no other codes.
Last edited by 95F150MTR; Jul 26, 2010 at 11:21 PM. Reason: Forgot to add something!
Old Jul 27, 2010 | 10:32 AM
Kemicalburns
did you follow the adjustment procedure for your new tps from Ford Fuel Injection.
what did you use to clean the throttle body? regular carb cleaner is not to be used.
Old Jul 27, 2010 | 07:03 PM
95F150MTR's Avatar
95F150MTR
I'm working on the voltage right now.... so we will see how that goes
I did use carb cleaner cuz thats what was recommended to me to use. What should i have used? and what have I done to it?
Old Jul 27, 2010 | 09:40 PM
95F150MTR's Avatar
95F150MTR
Okay so heres where i'm at now. First sensor that was in there was bunk, was reading around 3volts when closed and wouldnt read any less than that, and the throttle wouldnt close. So went and got a new one, .98 volts at closed 4.88 at WOT put it all back together. Feels great, EXCEPT: tranny wont shift right away, holds in the gear for a really long time, feels like its slipping almost etc.
So unplugged the battery to reset everything, came inside for a bit, went back out and hooked it back up, now it wont start... ugh
And thats where I'm at!
Old Jul 28, 2010 | 10:20 AM
Kemicalburns
turns over but wont fire or battery dead and wont crank?
Old Jul 28, 2010 | 10:21 AM
Kemicalburns
have you checked fuel pressure yet?
5th One
1997 - 2003 F150
Nov 12, 2014 06:57 AM
lacustoms
Nov 4, 2010 03:46 PM
f150vt
2004 - 2008 F150
20
Oct 15, 2010 07:02 AM
jakefreeman78
Jun 30, 2008 12:21 PM
ozzy460
Nov 23, 2007 07:14 PM
