Points to electronic ?'s
Old Jul 21, 2010 | 12:46 AM
pcskies's Avatar
pcskies
I installed the Pertronix Ignitor in my stock 390 last weekend. Wired it to the + side of the coil leaving resistor wire as is. Can't believe the difference it made. Didn't have to adjust timing either. Starts, Idles, Runs great. Best 74 dollars I ever spent.
Old Jul 21, 2010 | 08:10 AM
pidaster's Avatar
pidaster
What are the part numbers you used? Did you replace the coil as well?
Old Jul 21, 2010 | 09:29 AM
akforceten's Avatar
akforceten
i had Pertronix Ignitor on my 390 it worked great for many years until the unit failed . the cost of a new one wasnt in the budget so for about $40 i converted to a duraspark setup an it works just as good as the Pertronix Ignitor
Old Jul 21, 2010 | 12:20 PM
ptalbert33's Avatar
ptalbert33
Pertronix Install
Thanks everyone! I guess I will just install the ignitor and flame thrower and see what happens. The truck is stock and has only 19,000 original miles. Not going to change to much on this one. So nobody messed with their spark plug gaps after installation?
Old Jul 21, 2010 | 12:24 PM
pcskies's Avatar
pcskies
I'll look for the part number later when I get home and post it. It is the original Pertronix Ignitor I. I did not change out the coil - it's working well with the stock coil.
Old Jul 21, 2010 | 01:02 PM
79FordBlake's Avatar
79FordBlake
1281 should be Igniter. 91281 should be the Igniter II.
Igniter II supposedly adjusts dwell through the entire rpm range and sences start up and supplys more energy for a quicker start. It also sences that the key has been left on after a certain amount of time and shuts itself off so it doesn't burn up.
Old Jul 21, 2010 | 01:15 PM
pcskies's Avatar
pcskies
Yes it was indeed 1281.
Old Aug 6, 2010 | 11:36 AM
ptalbert33's Avatar
ptalbert33
Ok, I installed the petronix ignitor into the my truck last week and drove it home from Colorado to Bay City, TX. I had the timing checked after installation at a midas and they told me it was a little off. Had the timing set and was off on the trip to Texas. I noticed that when I got up around 60 mph that it ran a little rough and wanted to cut out. It did die a few times and I would shake the wire that goes from the coil to the distributor and it would start right back up and then go dead again a little later. Eventually a put to old coil on and made it home fine. The truck still runs a little rough though. I did unhook the resistor when installing the petronix. Could that be the problem? Maybe I need to check the spark plug gap? Might need more of a gap after switching from points. Please let me know what you think.
Old Aug 6, 2010 | 12:11 PM
pcskies's Avatar
pcskies
I left my resistor wire in place. Since I'm running the 1281 Ignitor with OEM style coil I left the spark plugs gapped at .035. If I ever go to a hotter coil I'll consider better plugs and a wider gap.
Make sure your ground strap inside the distributor is properly seated. When I did mine I removed the strap completely and cleaned up the end terminals. Then I took some acetone and a rag and carefully cleaned up the inside of the distributor as well. You want to make sure the inside of the distributor is as grease and dirt free as possible.
Let us know how it goes.
Old Aug 6, 2010 | 05:10 PM
ptalbert33's Avatar
ptalbert33
There is no ignition control module is there? I think that my distributor has to much play in it and that is why I am running so rough. Replacing the distributor tomorrow morning and will see what happens. I found a rebuilt distributor with an electronic conversion kit already built in it for $48! After core return. Sounds to good to be true.
Old Aug 6, 2010 | 11:13 PM
lance65's Avatar
lance65
you can always do a DS II using junkyard parts....
or you can used the DS II distributor and a GM HEI module with a TFI coil
I have had too many Pertronics fail on me.
Good Luck
-Lance
Old Aug 7, 2010 | 12:26 PM
pcskies's Avatar
pcskies
Let us know how that replacement distributor works for you.
savenow1501
Nov 3, 2020 10:13 PM
My1964ford
19
Feb 25, 2015 02:46 PM
1981fordstepside
Jun 10, 2014 01:15 AM
amosmoses
Feb 29, 2012 08:33 PM
UserM6459
Jul 11, 2006 04:13 AM
