Offroad & 4x4
gear ratios
Old Jul 19, 2010 | 07:20 PM
johnboggs21's Avatar
johnboggs21
gear ratios
How do I figure out the gear ratio in the rear of my truck? Its got a 10.25 sterling. The tag on the axle is too far gone.
Old Jul 19, 2010 | 08:13 PM
captain p4's Avatar
captain p4
If the truck is all original there should be a tag in the door with the axle code on it, get that and then head up to your specific truck forum and there should be a decoder somewhere in there. You can also figure it out by driving at a certain speed, say 65 with the tq converter locked and calculate it based on the OD ratio/tire size/engine rpm/speed (maybe verify it with a GPS if tire size isn't stock). One more way to do it is to jack the truck up and put it in neutral, then turn the tire one revolution and count how many times the driveshaft turns.
Old Jul 19, 2010 | 10:08 PM
fatdan460's Avatar
fatdan460
this is the only part of this post that made any goddamn sense to me. make sure both tires turn the same amount of revolutions just in case you have an open diff(it can lead to wrong readings) chances are, unless it got swapped at some point in time, it is either 3.55 or 4.10, unless it is a super duty. mark it in a spot with tape or chalk, and count the dshaft rotations until that marked spot comes back to the same position. it is not an exact science, but you get the gist.
Old Jul 19, 2010 | 11:10 PM
73 ford guy's Avatar
73 ford guy
Pull the cover and read the stamped #'s on ring gear! Done
Old Jul 20, 2010 | 12:33 AM
fatdan460's Avatar
fatdan460
that works too, but i value my silicone
Old Jul 20, 2010 | 01:39 AM
Prozon's Avatar
Prozon
Not to mention then he has to get all messy with the gear oil.. easiest just to turn the tires and count the drive shaft rotations.
Old Jul 20, 2010 | 04:29 AM
Bender99's Avatar
Bender99
Or he could tell us the tranny, tire size and how many rpm's at 65 and someone should be able figure it out. If you have a 5 speed I can probly tell ya, I've had many combo's with 5speeds
Old Jul 20, 2010 | 06:37 AM
gfw1985's Avatar
gfw1985
Cranky Old Guy
Or you could just use this: Gear Ratio Calculator
Old Jul 20, 2010 | 03:06 PM
captain p4's Avatar
captain p4
yep, therer are about a brazillion ways to figure it out.
Brian429
2015 - 2020 F150
Nov 23, 2016 11:51 AM
jamusfam
Apr 24, 2014 06:20 PM
thinksnow
Sep 14, 2013 01:31 PM
97puller
Aug 28, 2010 06:59 AM
jrodeo
Jan 9, 2003 08:49 PM
