Towing issue / problem / question
Old Jul 19, 2010 | 05:48 PM
FSJ-EARL's Avatar
FSJ-EARL
I was hauling my buddie's Jeep J20 pickup truck with a CUMMINS 4BT in it this weekend to go to a jeep show and my trucks rear end was wiggling and waggling all over the place. Did NOT matter the speed. It would get slightly better under acceleration but then get worse as I eased up on the throttle. I tow my Jeep J10 trail truck all the time with no issues. I am wondering if the added weight of hte heavier engine in the Jeep made my normal trailer location incorrect. I watched both side of the trailer and saw no tire wobble, no bounce no nothing. I am driving a stock 2002 F350 with no suspension or tire mods. Any ideas, thoughts, suggestions? Made me a bit nervous and with these trucks, towing should not be that nerve wracking. THANKS IN ADVANCE!
EARL!
Old Jul 19, 2010 | 05:56 PM
big poppa's Avatar
big poppa
The only thing I can think of Earl is was their enough air in the rear and front tires for that matter?? Hauling heavy to medium heavy you got to air up those tires..
rbaker6336's Avatar
rbaker6336
Somewhat sounds like you you didn't have enough tongue weight or as Mike said,soft tires
Old Jul 19, 2010 | 05:59 PM
racincowboy's Avatar
racincowboy
Or too much tongue weight. I have had that issue before and it isnt a good feeling. How long of a trailer was his jeep p/u on?
When you loaded it on the trailer how much did your truck squat as you came forward on the trailer? Was the rear end touching the overload pads on the frame?
puller45's Avatar
puller45
How did you load the jeep? drive on, back on? weight should be a little heavier ahead of the trailer axels. Could your rear truck tires be low on air? How fast were you traveling? There are a lot of varibles when loading trailers, but these are the basics that come to mind.
Old Jul 19, 2010 | 06:00 PM
FSJ-EARL's Avatar
FSJ-EARL
Nope, tires all the way around were good. Truck and trailer. Could I have had too much tongue weight?
Old Jul 19, 2010 | 06:05 PM
rbaker6336's Avatar
rbaker6336
I guess you could have too much tongue weight.that would be pretty evident looking at it.Depending on what i haul I normally load till the hitch drops 1 1/2" from empty
puller45's Avatar
puller45
Too much or too little will both give you trouble. I worked 20 years for Wa state DOT on the highway, almost all trailer accidents that I helped with were 1. to heavy in the rear 2. too much speed, or a combination of both.
Old Jul 19, 2010 | 08:01 PM
FSJ-EARL's Avatar
FSJ-EARL
The overloads were touching. The truck was on the trailer with the engine in the front. I was doing about 50 - 60 mph on a relatively flat good condition highway. I have a 16 foot car trailer. This was the first time towing on my BFG All Terrains, but they are the same load rating as my previous tires, same size as well.
Old Jul 19, 2010 | 08:22 PM
racincowboy
I would venture to say you had too much tongue weight. A 16 foot car trailer with a full size jeep p/u like that you have to have a ton of tongue weight just to get it on the trailer. Not to mention the added weight of that cummins motor in there. I dont know what that cummins weigh but i know it is a bit more then the big block or small block that was in the truck factory.
Were your truck tires at max cold pressure as well?
Your trailer tires all the same pressure?
I pulled home a j20 on my 16ft car trailer and it did the same thing. Was very unnerving and not a fun ride. That is when I got rid of my 16 ft and got a 20 ft car trailer.
Is your car trailer axles set back from center at all?
Mine were set back 6 inches from center so that didnt help my situation any either.
Did you happen to weigh that j20 vs. the weight of your j10?
Are they both the same wheel base?
Old Jul 20, 2010 | 01:53 PM
westpsd's Avatar
westpsd
New BFG's tend to be squirmy to begin with until some of the tread gets worn (my experience from several sets). Add that to probably heavy tongue weight and probably an unlevel trailer (nose down) would give you a fit. In my experience, an unlevel trailer is the most un-nerving pull you can do. Not only does it tend to squirm and whip, but every time you hit a bump, you can feel it "push" the tow vehicle forward, slapping you in the back. Sounds like you may have had the perfect storm. If it was pushing your springs down that much, next time try loading it on backwards. Just make sure you get enough tongue weight. Too little is worse than too much.
Jim
Old Jul 20, 2010 | 02:22 PM
kccatpower's Avatar
kccatpower
how much drop were you using on your reciever? i hauled a suburban for a friend and experienced the same thing, i went from a 4" drop to a 2" drop and was able to smooth out the ride some.
Old Jul 20, 2010 | 06:12 PM
dn29626's Avatar
dn29626
I am guessing your truck is SRW and the trailer is tag-a-long.
FSJ-EARL
Oct 22, 2012 01:09 PM
FSJ-EARL
19
Sep 10, 2012 10:07 AM
FSJ-EARL
20
Oct 3, 2010 03:19 PM
ATXZJ
Modular V10 (6.8l)
Feb 15, 2007 07:13 AM
jebdrup
All Things Towing
Mar 28, 2006 11:14 AM
