Dropping fuel tank??
Old Jul 19, 2010 | 02:46 PM
jtybt's Avatar
jtybt
'00 E 350 PSD
Before I break something...
What is the procedure for removing the fuel tank sending wire connector on the top of the tank?
And, is there a special way of separating the quick connect fittings?
Thanky all,
Charlie
Old Jul 19, 2010 | 03:52 PM
Robert6401's Avatar
Robert6401
The sending unit wire will just come off. You may have to bend a little tab out of the way to remove it, but mine came off real easy. You need to go to an autozone or somewhere similar and get a fuel line removal tool to get the quick connect fittings off. They won't come off with just your hands.
edit: here is a link to the kind of tool I'm talking about. You will need one of the 3/8 variety for at the tank. If you are removing the line going to the pump you will also need one of the 5/16 variety. Or you can get the one that has both (part number 6509):
http://www.autozone.com/autozone/acc...mString=search
Old Jul 19, 2010 | 04:18 PM
jtybt's Avatar
jtybt
Ahhhh! Found the wire connector. On my way to get the dis-connect tool.
Thanks,
Charlie
Old Jul 19, 2010 | 08:35 PM
jtybt's Avatar
jtybt
Took the cannister apart. The fuel pick-up cone goes directly into a compartment at the bottom of the cannister where the return line is also routed and mix with the tank fuel. From there, both the return fuel AND tank fuel are routed to the upper cannister where the mixed fuel finally go up the pick-up tube.
I guess it makes sense in sub freezing weather.
charlie555
Mar 26, 2015 09:50 PM
cldomson1
6.7L Power Stroke Diesel
Apr 21, 2013 09:14 PM
charlie calcote
Sep 15, 2011 10:58 PM
charlie268
1983 - 2012 Ranger & B-Series
May 2, 2010 10:36 PM
