Decel fuel shutoff
Old May 1, 2010 | 07:39 AM
charlie268's Avatar
charlie268
Decel fuel shutoff
Does anyone know which sensors supply the info to the computer for the decel fuel shutoff???
Old May 1, 2010 | 09:57 AM
reddog99's Avatar
reddog99
That would be the Throttle Position Sensor.
Old May 1, 2010 | 04:01 PM
charlie268's Avatar
charlie268
Well I have a 2000, with 4.0, 4wd, off road package. Now to the problem, with the transmission out of overdrive, in 4th gear, and you let off the gas, at approx 1500 rpms it just slows down like really quick. It will drop down to like 800 very fast. It's just like a jake brake on a truck. I read a posting over in ranger station that a guy had the same problem. The replies were about a decel fuel shutoff that all fords with efi have it. It really does bother you when you are slowing down.
Old May 2, 2010 | 08:42 AM
daveeich337's Avatar
daveeich337
not like that. I think its only supposed do its job if you hit something. Then you would have to manualy reset it for the engine to get fuel.
Old May 2, 2010 | 10:36 PM
reddog99's Avatar
reddog99
daveeich337, You're thinking of the emergency fuel pump shut off. DFCO (Deceleration Fuel Cut Off) operates pretty much as the OP describes, except it usually will stop somewhere in the range if 1500 rpm (at least, it does on my truck).
Charlie268, When you take the truck out of overdrive, the torque converter locks, and thus it acts somewhat like a stick shift when you let off the gas. That is, the vehicle will have engine braking and DFCO will become active more easily. This is completely normal and it's the way it's supposed to function. But I've never seen it continue until down to 800 rpm. I would expect that to produce stalling problems. If you want coasting, leave the overdrive engaged.
obscurity
Mar 7, 2016 08:04 PM
carguy3j
82
Oct 11, 2015 08:53 PM
N.W.Ford
May 30, 2014 08:50 PM
spcw1234
Oct 20, 2011 02:11 PM
inkmanj
23
Nov 9, 2009 06:11 AM
