Lacking towing guts
Old Jul 13, 2010 | 10:28 PM
gnamias55's Avatar
gnamias55
Lacking towing guts
I have a 99 F250 PS 7.3L w/ approximately 280k miles. I tow a 22' bay boat that weights approximately 2500-2500 lbs with trailer included. I have gradually noticed a "lack of guts" when towing the boat. I have done most of the regular maintenance on the vehicle (oil,trans fluid,water pump, alternator, etc.) I was curious if 1) is there any special maintenance that this particular motor requires (glow plugs, valve clearance, turbo etc.) 2) what would cause a slight lack of power under tow? Thanks
Old Jul 13, 2010 | 10:57 PM
Izzy351's Avatar
Izzy351
That's not much of a load. Are you seeing any black smoke? I would suggest you look for boost leaks, especially if you never tightened the boots on the I/C tubes/spider...
Old Jul 14, 2010 | 09:48 PM
gnamias55's Avatar
gnamias55
I'm not seeing any smoke, but when I stop the truck, sometimes I can catch a funny odor coming from the engine compartment...hard to describe what it smells like. I'll check the boots and post the outcome. Thanks.
Old Jul 14, 2010 | 10:43 PM
BigAlsPSD's Avatar
BigAlsPSD
Maybe leaking Up-Pipes? Or based on the odd smell? Maybe transmission fluid burning?
Old Jul 16, 2010 | 09:06 PM
gnamias55's Avatar
gnamias55
I changed the trans fluid and filter about a year/7K miles ago. No signs of excessive wear. It's holding fluid well and doesn't have a burnt smell. I did notice this past winter that on cold mornings after letting the engine warm up some, that as I would accelerate and the trans shift up to third gear the engine would run rough. I could give it gas and accelerate to cause the engine to downshift into second and then accelerate for a bit and then when I let off the gas and the engine would shift back into third, the shaking would go away. I'm no mechanic, but worried it could be something with the engine and not drivetrain. I will apologize before showing my ignorance, but what is the "up-pipe"?
Old Jul 16, 2010 | 09:32 PM
riverrat41's Avatar
riverrat41
Do not apologize here.There are absolutly NO dumb questions here.Ask away.
WELCOME....On that vibration.Have you checked all u-joints even on the front shaft if it is 4x4?
Old Jul 16, 2010 | 10:10 PM
gnamias55's Avatar
gnamias55
I did have a rear end vibration and replaced the rear U joing (was pretty bad) and it cured that problem. It feels like what I would potentially consider a misfire?? skip?? compression issue? Again...its strange how it doesn't do it in first or second gear while accelerating. And more peculiar that when jumping on the gas for about 5 seconds and getting the truck to shift from 3rd, accelerate in second, back to third, will cause it to go away. Only does it when the engine hasn't had adequate time to extensively warm up. Rarely an issue during the summer, much more previlant in the winter and I'm usually saved by the block heater.
Old Jul 16, 2010 | 10:16 PM
orng1's Avatar
orng1
Feels like a mis, lack of power. I think it sounds kind of like you may have a loose injector plug or maybe a bad injector. Worth a shot to check the under valve cover harness.
Old Jul 16, 2010 | 10:44 PM
gnamias55's Avatar
gnamias55
How would I check the injectors and how difficult is it to replace it/them? I'm assuming this is all under the valve covers?
Old Jul 16, 2010 | 11:18 PM
orng1's Avatar
orng1
If it's missing check the injector harness to see if any are loose. if none are go ahead and disconnect each one to see which one is the one causing an issue.
Old Jul 17, 2010 | 07:56 AM
bfife's Avatar
bfife
still plays with trucks
hard miss when cold? mine did this for awhile. miss like a pig and as soon as the engine warmed up, say 2-3 miles, it would smooth out and run great the rest of the day. turned out to be a bad injector. at 280K plus miles I would recommend looking into some injectors. you'll be amaized at how much better your truck runs with some fresh sticks.
just my experience
Barney
Old Jul 17, 2010 | 10:22 AM
Kwikkordead's Avatar
Kwikkordead
just my experience
Barney
I'll second this.
But the first thing that comes to my mind when you mention no pulling power is clogged fuel pickup screens.
It's a very common problem with these trucks.
You have to drop the tank to get at it.
Unfortunately you have to do this first to remove all doubt.
Old Jul 17, 2010 | 10:27 PM
gnamias55's Avatar
gnamias55
I appreciate all the advice!! I will check into replacing the injectors. Is this someing that DIY'er could tackle or even would it be recommended?? OR should I seek "professional" help?
Old Jul 17, 2010 | 10:33 PM
gnamias55's Avatar
gnamias55
Furthermore should I purchase Motorcraft or are the aftermarket brands ok? I would hate to try and save a penny and then be found guilty of "pay for what you get."
Old Jul 17, 2010 | 10:54 PM
orng1's Avatar
orng1
Don't just replace injectors, be sure you test them. It may be a clogged pick up line. It's not to difficult to test, I think it took me less than an hour to replace my harness when I had a leak.
