4.0 sohc blocks
Old Sep 14, 2011 | 09:50 PM
charlie calcote's Avatar
charlie calcote
4.0 sohc blocks
Hi
I just got a 2003 explorer with a broke rod and busted block, I need to know what year blocks will interchange with the 2003. Not flex fuel.
Thanks,
Charlie
Old Sep 14, 2011 | 11:02 PM
85e150's Avatar
85e150
Not sure on that one, but iirc 4x4 sohc motors have a balance shaft in the lower crankcase or off to the side, so there might be a difference there.
Probably easier to find an entire motor ain't it?
Old Sep 15, 2011 | 10:52 PM
goosehunta's Avatar
goosehunta
man that balance shaft thing is...well i think its a bad design. does anyone know the reason behind it. its only on the 4x4 correct?
Old Sep 15, 2011 | 10:58 PM
85e150's Avatar
85e150
Balance shaft is there to smooth out the not-as-smooth-as-an-in-line V6.
The 4.0 is a noisy bastid, so they put that balancer band-aid on it to make it a little more palatable.
reddog99
1983 - 2012 Ranger & B-Series
Mar 19, 2024 01:00 AM
mdelfunt
Jun 26, 2017 11:12 AM
oneowner83
Jan 13, 2014 02:01 AM
jimandmandy
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Mar 11, 2005 11:11 AM
