tarter replacement
Old Jul 19, 2010 | 01:01 AM
leardvr's Avatar
leardvr
tarter replacement
SORRY STARTER REPLACEMENT.
Well I bit the bullet an replaced the starter on my E350 w/460ci.
Pain in the a$$ to get the top bolt, but job done.
The old starter was using every little available cranking amp just to turn the starter it self. In fact when hooked to cheap jumper cables the old starter made them smoke.
It was so bad that I couldn't turn the van off if it was hot because it wouldn't restart.
Today I drove the van 5 hours in 90F. Turned it off to get gas and it RESTARTED.
FYI the old starters housing had holes in it, from the heat off the exhaust manifold, or at least on that side where it was closest to the heat. Wonder if that had anything to do with it??!!
Just thought I'd share. Now to remove the ac evaporator.
El Padrino
17
Mar 9, 2013 08:25 PM
bang4dabuck
Aug 7, 2011 11:06 AM
waynerwray
1978 - 1996 Big Bronco
Jun 9, 2004 11:32 PM
KJKozak2
Jan 12, 2004 09:25 AM
78f3504x4
Aug 2, 2003 08:03 PM
