Could someone explain to us uninitiated what these $100 mods are to the HPOP? I couldn't find anything like that on their website. I hate to call someone up and not even know what I'm asking about. I'm not talking about fixing leaks, I understand what that is.
I wish I could tell you, but I don't have a clue. I know he took my core 17 that wouldn't hold 1800psi, modded it, and now it holds over 2900psi at WOT. What ever he does is well worth it in my book.
If I may be so bold, what did that set you back, give or take? Can you send him your HPOP and he rebuilds it and improves the performance so you don't have to worry about it for a long time. Something along the same concept as the Red Head Steering box.
It was right around 100 bucks, IIRC. My truck had a stock 15* pump. Roland had just replaced his "weak" stock 17* with a stealth hpop. He gave me his stocker to use as a core for a modded 17*. After talking with Joey, he said for me to send it to him and he could improve it, rather than use it for a core. On Rolands truck the ICP would drop to 1800psi. After Joey modded it. It will hold over 2900psi on my truck at 60% DC at WOT. The new pumps that Joey mods have a lot better pressures than that. I just wanted to make it clear that my pump was toast before I sent it to terminator. It took about a week from the time I shipped it 'till I got it back. I can't say enough about Joey's customer service. Top notch!
Originally Posted by bama29fan
so what years have the 15* and which have the 17*
'94-early'99 had the 15's and late '99-'03 had 17's.
Okay, what do you need to complete the whole picture. Such as orings, reservoir and gasket, IPR, Hoses, sensors and anything else to make the HPO system as bullet proof as one can.
