Will this Fuel level gauge work?
Old Jul 17, 2010 | 09:41 PM
RangerHaywood's Avatar
RangerHaywood
PLEASE, tell me i can use this gauge in my 78 F-150! It says something about a fuel level sender? Is that fancy talk for a sending unit? I JUST put a brand new sending unit in my gas tank...
Sunpro CP8209 - Sunpro Analog StyleLine Gauges - Overview - SummitRacing.com
I really need this gauge to work, because i already have most of my custom gauge cluster done....
Old Jul 17, 2010 | 10:48 PM
MADFord4X4's Avatar
MADFord4X4
It will work if the gauge and the sending unit are mated together. If not then it might work or it could be off a little or a lot. You shouldn't mix and match sending units and fuel gauges.
But yes the fancy word fuel level is your gas gauge. Are both from Sunpro?
Old Jul 17, 2010 | 11:09 PM
650's Avatar
650
That gauge says it operates on 240 ohms empty, 33 ohms full but I believe that all 73-79 FORD gauges operate at 10 ohm full, 70 ohm empty. You could try it but if it doesent work they probably have the right ohms in one of their other gauges of the same size and look. Good luck though.
Old Jul 18, 2010 | 09:21 AM
RangerHaywood
No, i just put the brand new ford sending unit in it GRRR Ill see what i can do and report back to you guys!
Old Jul 18, 2010 | 12:30 PM
hp246's Avatar
hp246
Sunpro should have a sending unit that matches their gauge. You will have to take the guts of that sending unit and have it welded to the Ford pickup tube. You will need to play around with the level to get it to work right. It is truly a PITA, but I had to go through it when I iunstalled custom gauges in my truck.
Old Jul 18, 2010 | 12:33 PM
fmc400's Avatar
fmc400
MSEE
You're absolutely correct.
Old Jul 18, 2010 | 12:42 PM
hp246's Avatar
hp246
If you pm me with an email address, I can forward you directions I received that give instructions as to how to do this. I tried posting the document, but for what ever reason, I can't get it to transfer.
Old Jul 18, 2010 | 09:04 PM
RangerHaywood
No no no, thats quite alright. I think im gonna use the original ford gauge, but put the sunpro face on it, or something similar to that. Dont worry ill frankenstein something together!
f100today
58
Oct 25, 2015 01:54 PM
78fordbeast
Oct 4, 2014 09:06 PM
klx400
Jan 29, 2014 08:07 PM
