exaust leak... :(
Old Jul 17, 2010 | 09:37 PM
danger-ranger93's Avatar
danger-ranger93
exaust leak... :(
i just got done wit my headers and ran good no leaks nothing...now 2 days later its running rich and sounds like open headers, im finantualy drained right now, i need a cheap easy fix. any ideas??
Old Jul 17, 2010 | 09:41 PM
cjben's Avatar
cjben
the fix would depend on where it is leaking from. did the header bolts come loose? if so,it could be as easy as tightening them up again.
Old Jul 17, 2010 | 09:47 PM
danger-ranger93
i checked everything as far as bolts, its tight as the first day, i think its a crack some where in the pipe, but im unsure
Old Jul 18, 2010 | 12:42 PM
jplinville's Avatar
jplinville
I'd check the donut gasket coming off of the headers...if they weren't tightened properly, you could have damaged the "donut"
Old Jul 18, 2010 | 05:11 PM
danger-ranger93
i didnt have to have the donut i used shorties, with the ball and socket
Old Jul 18, 2010 | 05:40 PM
Conanski's Avatar
Conanski
Pull the fan off the waterpump pulley so you can run the motor without the hurricane and find where the leak is.
Old Jul 18, 2010 | 06:16 PM
danger-ranger93
its behind the motor because up front it sounds like it did when i had manifolds i really think its a crack somewhere in the pipe because who ever did the pipes didnt bend them with the seam, its goin to the muffler shop when i get the cash built up, im just loooking for a way to seal it so its not as bad and i wont go crazy listening to it
Old Jul 18, 2010 | 06:59 PM
f-150_1993's Avatar
f-150_1993
Oh no buddy Hope problem gets solved soon. BTW before this happened... did you notice performance gains?
Old Jul 18, 2010 | 07:54 PM
danger-ranger93
ohh yea a lot more pick up in her and i could hold 2nd gear until i was at 35 and 3rd would go to 50 and previously it wouldnt make it to 45 befor i had to shift it was nice
Old Jul 18, 2010 | 08:05 PM
93MARKIII's Avatar
93MARKIII
do you have any seafoam ??
if yes, the pour it into the brake booster vacuum line until the engine dies......make sure the *** end is down wind......and let it sit for about 20 minutes.....crank her up and look for the smoke....you will find any leaks real fast......and you clean the carbon on top of it !!
not sure if being that close to manifolds would work, but you could try some muffler bandage to try and temp plug it off till you can get it fixed
Old Jul 18, 2010 | 08:17 PM
danger-ranger93
i have seafoamed it befor just to watch it smoke and did not even think of doing it agin to see the leak! man i feel so dumb...its been a good while since the last time i did it so it should smoke a good bit agin
THANKS!
Old Jul 18, 2010 | 08:34 PM
BearFootCustom's Avatar
BearFootCustom
Did you get the paper gaskets with them? If you did they suck and you should get metal ones...always check your header bolts to because mine come loose after 11,000 miles
Old Jul 18, 2010 | 08:38 PM
93MARKIII's Avatar
93MARKIII
yea, best i remember headers need to be torqued every few months to keep the bolts tight, and especially the first few times you run the truck after installing due to the heat/cold cycle
Old Jul 18, 2010 | 08:43 PM
danger-ranger93
i used fel-pro gaskets on them
Old Jul 18, 2010 | 08:45 PM
danger-ranger93
I'll check'em agin but i really dont think they've come lose yet cause everything is still tight but i'll check tommarow
