Coning rear tires
Old 07-17-2010, 07:48 AM
SouthpawMason's Avatar
SouthpawMason
SouthpawMason is offline
Coning rear tires
Can anyone think of why my rear tires are coning? I had them rotated about 3 months ago and they look like they are still fronts.
Old 07-17-2010, 09:15 AM
rla2005's Avatar
rla2005
rla2005 is offline
Received 1,193 Likes on 942 Posts
Silly question...were they "coned" before you swapped them? Even though they are now on the rear the wear pattern is not going to magically disappear. If they were not coned then I suspect tire pressure is the problem.
Old 07-17-2010, 01:13 PM
threewhd's Avatar
threewhd
threewhd is offline
If you rotated them front to rear it will not go away for a long time. The proper way of rotating tires on a RWD/4WD application is. Remove rear tires move strait to front. Remove front tires and cross going to the rear. As in LF tire will go to the RR and the RF tire will go to the LR.
Old 07-19-2010, 04:22 AM
TexasGuy001's Avatar
TexasGuy001
TexasGuy001 is offline
I don't ever do the cross rotation on any tires. I have seen issues from it in the past. I know that some tire shops recommend it, but I won't ever do it again.
I will also agree that if the front tires are now in the back and they haven't been rotated in a long time they will have less shoulder tread and more center tread.
mmm635
6.7L Power Stroke Diesel
24
12-24-2020 06:41 AM
Mminalpine
1999 to 2016 Super Duty
12-11-2016 08:49 PM
Quizzack
19
07-02-2014 11:57 PM
hasteranger
03-01-2012 04:57 PM
Mikeman
1983 - 2012 Ranger & B-Series
05-17-2004 07:11 AM
Quick Reply: Coning rear tires
