Sponsored by: Auxito
rough idel trouble codes
Old Jul 16, 2010 | 04:29 PM
Cdy1's Avatar
Cdy1
its a 2003 with a 4.6, it has a rough idel and the codes are.. P0171 and P0174, fuel system too lean (cylinder bank 1/2)?? any ideas
thanks =]
Old Jul 16, 2010 | 10:15 PM
Bluegrass 7's Avatar
Bluegrass 7
This is very often an air leak through a bad hose somewhere on the intake manifold.
The only way the system has to ID the fault is by the OX sensors.
They shift the fuel tables trying to account for the extra air.
When the tables are shifted out of normal range, the codes are set.
The trick is to know the dynamic operation, because the codes do not tell you what part is faulty.
Good luck.
Old Jul 21, 2010 | 09:39 AM
Cdy1's Avatar
Cdy1
found it. thank you =]... does anyone know where the cabin air filter is in this truck??
itsunday25
13
May 15, 2011 08:34 PM
chuck 3902
1997 - 2003 F150
Jan 5, 2011 12:51 AM
ksw390
Mar 28, 2010 04:54 AM
deronyv8
1983 - 2012 Ranger & B-Series
Apr 2, 2008 10:46 PM
duck head
Feb 12, 2007 09:46 PM
