2004 ranger check engine light
Old Mar 23, 2008 | 09:32 PM
deronyv8's Avatar
deronyv8
I have a 2004 ford ranger with the 3.0 v-6 and almost 80,000 miles. manual tranny. My problem all started last night i was driving home and the check engine light came on. It is ideling really rough now. I got a hold of a scan tool and it was showing a code of p304 wich means it is missfiring on number 4 cly. I put a new set of autolight plantium plugs and reset the code. no change still idels rough. At freeway speed it seems to run ok. Also every now and then the check engine light starts to flash. Any help will be greatly apreciated. Thanks fellow ford fans.
Deron Siegel
San Diego CA
Old Mar 23, 2008 | 10:33 PM
aquajock's Avatar
aquajock
From my understanding when it flashes it means there is a chance you are messing up a catalyst component
Old Mar 24, 2008 | 06:57 AM
scottm's Avatar
scottm
Could it be a sticky injector?
Old Mar 24, 2008 | 09:33 AM
freirefishing's Avatar
freirefishing
id replace wires as well
Old Mar 24, 2008 | 08:57 PM
deronyv8's Avatar
deronyv8
put a new set of wires on today and that not make a bit of differance. dont know how to check the injection. if any one could point me in the right direction that would be great.
Old Mar 26, 2008 | 12:29 AM
deronyv8's Avatar
deronyv8
found out today that is a valve seat that went bad. was a common problem now ford has an impooved head for it
Old Mar 29, 2008 | 11:42 AM
aquajock's Avatar
aquajock
Did you take it to the dealer or troubleshoot on your own?
Old Mar 30, 2008 | 03:32 AM
deronyv8's Avatar
deronyv8
litte of each did all normal things to check for. than i did a compression test and the nuimber 4 cly was really low compared to the rest. then i took it to dealer. they are fixing it now cause i have an extended warnanty.
Old Apr 2, 2008 | 10:46 PM
aquajock's Avatar
aquajock
I took my truck to the Dealer today and just got a call that I have low compression in #6 and that it is a problem in my valve train. From this they say that I need a new engine because I have a 120,000 miles on the truck. They don't recommend just fixing the head.
Tyler Labaume
Oct 21, 2016 02:16 AM
ISLAND JACK
2004 - 2008 F150
Dec 6, 2014 07:50 AM
ksw390
Mar 28, 2010 04:54 AM
4inchlovin
16
Feb 22, 2008 08:29 AM
frazier23727
1997 - 2003 F150
Jan 29, 2004 08:27 PM
