p0603
Old May 12, 2011 | 10:52 PM
itsunday25's Avatar
itsunday25
p0603
ok i got a 1999 ford f 450 diesel no engine light but put scaner to it and it is saying kam p0603 code. and my exbpv is noy closeing and my high idel is not kicking in when E brake is down. just the other day it worked the high idel kicked in and exbpv and it hasent kicked back on sins. could you guys help thanks.
Old May 13, 2011 | 01:08 AM
clintbonnie's Avatar
clintbonnie
You are probably using some kind of progammer, etc.. and you will get this code.. pretty normal.. Or maybe you disconected your batteries recently... see:
https://www.ford-trucks.com/forums/9...-0603-pcm.html
And a Big Welcome the forum..
Old May 13, 2011 | 01:14 AM
bluescrew's Avatar
bluescrew
i would think the sensor needs replacing. just had that code and a bad sensor
Old May 13, 2011 | 07:50 AM
itsunday25's Avatar
itsunday25
i do not have a programmer it is all stock and wat sensor.
Old May 13, 2011 | 10:41 AM
clintbonnie
DId you buy the truck new ? If not, maybe the previous owner had a programmer or chip.. Did you disconnect your battery recently ?
Old May 13, 2011 | 10:49 AM
bluescrew's Avatar
bluescrew
i dont have a programmer either. ebp sensor
Old May 13, 2011 | 11:08 AM
DB Guy's Avatar
DB Guy
The code is a Keep Alive Memory...
Meaning you cleared the codes, disconnected the batterys or otherwise messed with the PCM in some way.
Has nothing to do with the High Idle or the EBPV...
The EBPV will not close unless the temps are low enough for the PCM to call for it, same thing with the High Idle... Unless the temp and other parameters are met it will not do this.
Old May 13, 2011 | 11:11 AM
clintbonnie
This sensor will usually give a 0475 or 0476 code when bad ..
Old May 13, 2011 | 10:57 PM
itsunday25's Avatar
itsunday25
i got the truck off the reg owner. didi not look like he had a programer on it. i did take the batters out to put a new ones in.
Old May 14, 2011 | 12:47 AM
clintbonnie
That's probably whats giving you the code..
Old May 14, 2011 | 01:09 AM
PaysonPSD's Avatar
PaysonPSD
P0603 - PCED - Internal control module KAM error - Open PCM pin, disconnect B+, faulty PCM
Disconnecting positive cables on batts is disconnecting B+. You can reset Keep Alive Memory to cler the code.
Old May 14, 2011 | 06:59 PM
itsunday25's Avatar
itsunday25
is that bad open pin ? cuzz it will run good then it will not. and my mph gauge will not work then it will idk wats up. i need it fixed be for next week cuzz i am pulling a rock cwroler to camp. thanks
Old May 15, 2011 | 10:18 AM
PaysonPSD's Avatar
PaysonPSD
Shoukld have mentioned these 2 things in your first post.
it will run good then it will not:
This could be a loose UVCH (Under Valve Cover Harness) or burned center pin.
50 Cent Mod for loose UVCH Burned Center Pin
my mph gauge will not work then it will:
Intermittent speedo can be a bad VSS (Vehicle Speed Sensor) on top of rear diff.
Old May 15, 2011 | 08:34 PM
itsunday25's Avatar
itsunday25
k thanks guys i will look at it in the morning. i had sume people it could be the pcm but i dont think so or could it thanks idk much about the fords i work on cat diesel.
TheK-Man
Mar 19, 2017 10:42 PM
Norma stitz
Oct 8, 2016 09:16 AM
lstitt
Australia Chapter
Dec 22, 2015 02:43 AM
fordman1986xlt
Mar 3, 2013 04:25 PM
04gray350
Dec 12, 2010 08:39 PM
