Sponsored by: Auxito
Auto-Climate Control help please
Old Aug 18, 2010 | 06:51 PM
projectSHO89's Avatar
projectSHO89
ericatp01,
Full battery voltage is applied to one terminal of the blower via the blower relay. Speed is controlled by varying the effective resistance of the return side of the circuit electronically by the blower speed controller (BSC) module under the control of the EATC module.
If you have no voltage on the BSC side of the blower but have the battery voltage on the relay side, the motor is bad, probably due to failed brushes.
Old Aug 18, 2010 | 07:20 PM
ericatp01's Avatar
ericatp01
Thank you very much for your reply.
I have NO voltage shown at the speed control box. There is a ground wire, a red wire (small) and a brown wire (I believe it is brown) that is the same size as the ground wire. I show no voltage at these points.
Also I verified I have no voltage to either side of the blower motor connector. That would seem obvious since I had no voltage to the speed control box, but I checked it again anyway.
Leaving the relay under the dash in the flasher housing, I see voltage and the relay seems to be working normally.
Im normally very good at electrical trouble shooting, but Im kind of shooting blind here.
Thank again for the help. It is much appreciated.
Eric
Old Aug 18, 2010 | 08:47 PM
projectSHO89
Grab schematic: 2000 Expedition EATC BSC.pdf
It's easier if you can see how it's supposed to work. Check fuse F105 under hood and fuses F2 and F22 under the dash while you're at it.
Old Aug 18, 2010 | 11:24 PM
ericatp01's Avatar
ericatp01
Thank you. I'll work the system tomorrow. Eric
Old Aug 19, 2010 | 11:12 AM
ericatp01's Avatar
ericatp01
Ok, again thanks for the diagram. Here is the deal. The relay in the Blower / Flasher block is not closing. When power is turned on I get power to connector 86 on the relay, but there is no ground made on connector 85 though the EATC.
Based on this diagram it looks like the EATC has a failure that is not allowing it to complete the ground circuit for the relay to close. Everything else works normally on it.
I removed the cover on a replacement relay and verified it was not closing. I then mechanically closed the relay with my finger and the blower powers up and works normally.
It seems really odd to me how just the one circuit in the EATC control module could cause this but I don't see anything else obvious.
Any other ideas.
Thank you,
Eric
Old Aug 19, 2010 | 07:40 PM
projectSHO89
I'd suspect a a failed output driver chip or transistor if there is continuity between the output pin of the EATC and the relay coil.
Based on the cost of a replacement EATC, I'd be hot-wiring that sucker so the relay energizes whenever the ignition is in RUN or something similar
Old Aug 20, 2010 | 11:15 AM
ericatp01's Avatar
ericatp01
That is exactly what I did. I grounded the relay with a 1amp fuse in line. The fan comes on whenever the ignition is hot. Way too much money to replace the EATC just for this.
Thanks again for all the help!
Eric
Old Sep 20, 2010 | 10:42 AM
mcn420's Avatar
mcn420
I'm back to working on mine again The new blower motor I put in from AutoZone only lasted a couple months! Possible bad part, or maybe there was too much amperage being drawn. It's lifetime warrantied, but that thing was a PITA to put in!
Anyway, does anyone know what acceptable amperage is for that motor to be pulling? I found the motor's bad by plugging in the original which still works, but is somewhat harder to turn, and possibly making it draw too much amperage. At any rate I just wanted to check there's not too many amps being drawn after I install the next blower fan.
annaleigh
Jul 24, 2016 09:11 PM
aero993
Jun 12, 2016 10:43 PM
CGMKCM
6.7L Power Stroke Diesel
May 13, 2016 01:43 PM
bill57
1997 - 2003 F150
Jun 18, 2014 06:46 AM
kovi
Aug 26, 2013 02:30 PM
