Modular V10 (6.8l)
diff. gear change???
Old Jul 20, 2010 | 02:15 PM
Mr-Pipeline's Avatar
Mr-Pipeline
P-nut,
Performed the upgrade yourself, GREAT! Was this your first time? Any special tools or advise you could share with us. I'm considering upgrading from 3.73 to 4.56 but not sure I have the skills and very interested how the process went for you.
Old Jul 20, 2010 | 02:42 PM
p-nut's Avatar
p-nut
Originally Posted by Mr-Pipeline
P-nut,
It was my first time. It was easy, just took alot of time. Some of the tools required are a vernier caliper or micrometer to measure shims, a magnetic based dial indicatior to measure backlash with, a torque wrench, breaker bar, pry bars, made a tool to hold the yoke from spinning when loosening the yoke nut, feeler guages.
I ended up using the stock carrier shims and adding to the pinion to get the wear pattern correct.
Old Jul 21, 2010 | 11:45 AM
Mr-Pipeline
First,
Welcome to FTE!
This is a hot topic around the V10 area. I'm sure A LOT of folks would be greatful if you could share your step by step procedure with all of the gotcha moments. I think more owners would attempt the upgrade if we could remove some of the mystery in the process. Thanks!
JIMBO_FID
Sep 23, 2015 11:21 AM
Boss08v10
Modular V10 (6.8l)
May 14, 2012 09:45 PM
RadRick
Modular V10 (6.8l)
Sep 19, 2007 01:02 AM
LSchicago2
Modular V10 (6.8l)
33
Dec 30, 2006 12:24 AM
forddaddy
Modular V8 (4.6L, 5.4L)
Apr 10, 2006 07:34 PM
