Torque peak/rpm range
Old Apr 5, 2006 | 05:11 PM
forddaddy's Avatar
forddaddy
Question Torque peak/rpm range
Anyone know where at what rpm a 2003 5.4 makes it's peak torque? I'm looking at changing rear gears on a supercrew for towing a 7000 travel trailer but I'm already turning 2500 rpm @ 62 mph with overdrive locked out. If I change to a 3.73 or 4.10 gear with a 2wd and 16" wheels, where would my rpm's be @ 60-65 mph?
Old Apr 6, 2006 | 12:15 PM
kspilkinton's Avatar
kspilkinton
What's the tire height on the 16's? There are many online calculators to find this information out.
I went ahead and used my stock tire height of 29" to give me the following results -
3.73 - at 65 mph with od locked out ~2900 rpm, with od on ~1900 rpm
4.10 - at 65 mph with od locked out ~3200 rpm, with od on ~2200 rpm
Best fuel mileage is around 1800 rpm
The torque peak is at 2,500rpm, however the engine makes 75% of the 350ft-lbs at 1000 rpm. The torque curve is pretty flat for this engine.
-Kerry
Old Apr 7, 2006 | 09:58 AM
forddaddy's Avatar
forddaddy
Wink
Thanks kspilkinton, that's exactly what I was looking for. Great information.
Old Apr 7, 2006 | 01:38 PM
kspilkinton
Glad to help, I have the 2002 engine curves in a gallery. You may not be able to read them very well. They are the same for the 2003 engine.
https://www.ford-trucks.com/user_gal...&albumid=21045
Ignore the gallery header.
-Kerry
Old Apr 9, 2006 | 01:02 PM
2000BLK54's Avatar
2000BLK54
From most of the dyno graphs I've seen the torque peak is quite a bit later than 2500 rpms. Closer to 3200 rpms actually. Even with a supercharger my peak torque only shifted to about 3800 rpms.
Old Apr 9, 2006 | 11:13 PM
Dave23bme's Avatar
Dave23bme
what is the redline of a 01 4.6l in a supercrew? 2wd if that makes any difference
Old Apr 10, 2006 | 07:34 PM
kspilkinton
I believe the factory rev limiter kicks in at 5500rpm or so. I'm unsure if Ford would call that a redline.
-Kerry
evan.kelly978
26
Mar 11, 2015 11:50 AM
BlueOval460
18
Mar 28, 2012 10:18 AM
DHCowdude
Jun 15, 2011 11:05 PM
John with beastly 302
Aug 6, 2008 08:35 AM
matthew35
Oct 17, 2006 12:07 PM
