Mounting tail lights on '52 F-1
I bought a reproduction bed from Mar-k. At the rear on each stake pocket there are three holes (see photo). I know the tailgate hinge mounts to the lower two on the rear of the stake pocket.
I purchased stock tail lights and brackets. Where do they mount? Top two holes or lower two holes? Front of stake pocket or rear on the same side as the tailgate hinge?
Thanks
Fred
Thanks
Fred
Are all 3 holes drilled thru ? If so the hinge attaches to the bottom 2 . The middle bolt goes thru and attaches the bottom hole on the tail light bracket and the top hole is for another thru bolt for the top hole on the tail light bracket .The tail light bracket attaches to the back side of the stake pocket / side panel .If the bottom hole is only thru the one side slip a wrench with the nut attached and fasten . Hidden fastener .It is a PIA but makes for a clean mounting .
olguy317
01-28-2015 04:46 PM
jniolon
01-06-2012 09:44 PM
cts1954
03-01-2010 07:55 AM
