TAILGATE HINGE MEASUREMENTS
Old Jan 6, 2012 | 02:08 PM
jniolon's Avatar
jniolon
old and in the way
I need to verify some measurements for tailgate hinges on a '53
I need the measurement from the bottom of the stake pocket to the center of the bottom hole in the hinge
And
the measurement from the outside edge of the stake pocket to the center line of the holes...
I think the first one is 2-3/4" but want to make sure
thanks
John
Old Jan 6, 2012 | 08:08 PM
sdetweil's Avatar
sdetweil
On my green truck its 2-7/8 up from the bottom, and 1-3/16 from the outside edge of the stake pocket.
centered
Sam
Old Jan 6, 2012 | 09:08 PM
jniolon's Avatar
jniolon
old and in the way
thanks Sam
Mid 50 gave me a measurement of 17 5/8 down from the 45° break in the side wall down to the top of the hinge... and she said, "that's pretty close"... I don't do pretty close well....
I'd trust your measurements over anyone's... hopefully Sunday I'm gonna take all the bed crap off the truck and start assembling on a set of horses (saw horses)... once it's square and level, drill the front panel and work back.. maybe if I do right, the roll pan might match up better... (challange # 243.4)
is your front panel bolted from the bend over of the bed wall up thru the ears of the front panel ?>?
catalog shows it should be... my sides are only drilled for the fenders so I don't have a clue about any other holes needed.
j
Old Jan 6, 2012 | 09:44 PM
sdetweil's Avatar
sdetweil
Originally Posted by jniolon
thanks Sam
j
Yes, mine has bolts up thru the ears. The ears have the nuts welded on.
here is a pic of the ear on my bed, you can see where the nut retainer was welded to the front wall top rail..
Sam
tabascom16
May 28, 2015 09:09 PM
CharlieLed
34
Apr 20, 2011 09:10 AM
mark914
Dec 24, 2005 07:33 PM
jhnyrok
Oct 18, 2004 11:25 AM
Black&Tan
1997 - 2003 F150
Sep 17, 2004 03:08 PM
