Sponsored by: Real Truck
Vehicle Speed Sensor
Old Jul 15, 2010 | 08:35 PM
013specd's Avatar
013specd
Apparently this is on top of the differental, on a previous post someone said to check the differental fluid; on a F-250, 2001, 2WD is the differental not a sealed unit? Or is it able to be filled?
Old Jul 15, 2010 | 09:53 PM
Robs06SuperDuty's Avatar
Robs06SuperDuty
on the drivers side by the pinion there is the fill plug, take that out and stick your finger in. the oil should be about level with the fill hole.
Old Jul 15, 2010 | 09:55 PM
Deluxe05's Avatar
Deluxe05
I do not think that any of Ford's Super Duty axles were of a sealed design. If memory serves me correctly, they simply use a synthetic lubricant that does not require changing unless the axle has been underwater. Remember to get & add friction modifier if you have a limited slip rear axle & you drain & refill it.
Old Jul 15, 2010 | 10:16 PM
Robs06SuperDuty
ill beleive that when my shat turns purple, and smells like rainbow sherbert lol. I changed mine at 60K and im glad I did. I also put the 08 rear cover on. Yes you do need to add friction modifier when you change it, your limited slip will love you for it.
Old Jul 15, 2010 | 10:22 PM
Deluxe05's Avatar
Deluxe05
That's from Ford, not me. I, personally, would change it from time to time. No lubricant has the endurance to last forever & still provide the necessary lubricity needed by meshing metal parts, IMHO.
Old Jul 15, 2010 | 10:29 PM
Robs06SuperDuty
I know it is, I didnt mean to point fingers lol My rear diff fluid looked like death when I changed it. the front wasnt too bad. I put motorcraft stuff back in, dad works at the Dealership and I get a discount on stuff.
jbvsr
Oct 15, 2014 07:30 PM
foegezach
2004 - 2008 F150
13
Mar 9, 2011 12:40 PM
BLK 96
Nov 5, 2008 07:37 AM
Nor Cal ford
Jun 15, 2005 09:47 PM
