Another ball joint thread
Old Jul 15, 2010 | 05:49 PM
icantdo55's Avatar
icantdo55
1995 F250 manual locking hubs 5.8L 4x4 (dana 50 I think)
Got passenger side apart and upper ball joint is loose but lower is still stuck in there. Where can I beat it? I have beat it like crazy on the upper nut and the side of the lower and it wont budge, help.
Old Jul 15, 2010 | 07:07 PM
ac700wildcat's Avatar
ac700wildcat
When I did mine the only way i got them out was by pounding a pickle fork between the knuckle and the lower ball joint. Even with the pickle fork it took quite a few hits.
Old Jul 16, 2010 | 11:22 AM
icantdo55's Avatar
icantdo55
So I followed the advice of some on the board after some searching and flipped the castle nut over put it back on and hammered it....now the castle nut can work as a washer it no longer had threads.
Old Jul 16, 2010 | 11:38 AM
andym's Avatar
andym
Did you remove the nut from the lower balljoint? There's no way you beat on the castle nut so hard that you stripped the threads out of it.
Old Jul 16, 2010 | 11:51 AM
Dirt racer's Avatar
Dirt racer
Mine really came apart hard. I beat the crap out of it. Pickle fork. Torch and even cut it flush with a high speed cutting wheel, then drilled a hole most of the way through it. Then it finally came with the pickle fork. What a pain. It's a MN truck and everything is rusted on it.
Old Jul 16, 2010 | 12:08 PM
andym's Avatar
andym
Isn't it spelled Minnesota?
Old Jul 16, 2010 | 12:10 PM
icantdo55's Avatar
icantdo55
Lower nut off. Yes you can, I'll post a picture later.
Got it off with a pickle fork on the lower and a 10lb 3ft sledge.
Old Jul 16, 2010 | 10:46 PM
SofaKingBest's Avatar
SofaKingBest
I would have thought a ball joint press would have been a good idea. But too late for that now.
Old Jul 17, 2010 | 12:05 AM
Dirt racer's Avatar
Dirt racer
Thanks, I never noticed that for years. Must have had a few the night I wrote it. Glad he got the ball joint out. My neighbors cheered when mine finally came. I was beating on it for hours. Just like when I pulled down a tree with my truck but thats another story.
bchez
2004 - 2008 F150
May 7, 2014 02:07 AM
4caster
Feb 18, 2013 09:37 PM
labman1014
Sep 21, 2010 08:22 PM
z2896
2004 - 2008 F150
May 25, 2007 03:23 PM
Black85F150
Oct 24, 2003 04:11 PM
