weird problem( Electrical)?
Old Jul 15, 2010 | 01:00 PM
Reno348's Avatar
Reno348
Hello All,
I hope someone can help me out.
1.Turned off truck for (1) hour
2. upon re-start battery almost dead, insterment cluster acting strange
( no turn over)
3. Fuel pump clicking ** with ingition key turned off" and out of column
4. Tryed to jumpstart, Jumpers got extreemly hot so did the neg battery
wire on my truck. Started to smoke
5. Disconnected battery and left it alone
Items I checked:
1.Fuses at passanger side floor all good
2.pressed reset
3.removed fpdm near perfect condition
4.no code no power
5.Unplugged (2) plugs at drivers side frame, the ones with the plastic cover
over them
6.Was a good battery
Any input would shore help. John...
Old Jul 15, 2010 | 01:02 PM
shotgunz's Avatar
shotgunz
First, get the battery load tested. You may have a short in one of the cells.
Old Jul 15, 2010 | 01:06 PM
kevincw's Avatar
kevincw
If the neg. battery cable started to smoke, it's drawing to much current. Check for loose cable, charge battery and try again.
Old Jul 15, 2010 | 01:07 PM
2002sport's Avatar
2002sport
Sounds like maybe a shorted battery or wire if the cables got hot. My alternator went dead and that drained my battery while I drove it. Lights came on dim, and I had the clicking you explained, that's common with a low battery on these trucks, for some reasons the relays hang open with an almost dead battery. May check you're hot cable to the starter, and wherever else it runs from the battery for cuts or rubbing. Most other wires would be fused if they shorted.
Old Jul 15, 2010 | 11:24 PM
mikesheldon's Avatar
mikesheldon
It's definately the fuse problem.One of your fuse must be short circuit.If this is not the problem then the spark plug must creating a problem check for then moisture on the spark plug.take your car to a good mechanic shop.
Old Jul 16, 2010 | 06:22 AM
Reno348's Avatar
Reno348
Fixed
Thanks for your replies.
Thay shore did help.
The problem im am imbarrist to say was the battery.
In all my years of repacing batteries I have never seen anything like it.
No warning signs,fuel pump running with no key in it,could not jump.
Thanks again
John...
Old Jul 16, 2010 | 06:36 AM
shotgunz's Avatar
shotgunz
Yep - when the newer batteries go, THEY GO!
Depending on your climate (and how you use the battery), it's a good preventive measure to load test your battery every 3 years.
Old Jul 16, 2010 | 10:37 PM
Greg B's Avatar
Greg B
Been there and done that myself, reno. Only I didn't have this or any other forum to go to. I had to do it the old fashioned way and actually use the shop manuals to diagnoze. It was one of those duh!! moments when I finally found the cause.
Old Jul 17, 2010 | 11:00 AM
bridge's Avatar
bridge
Sick 'n Tired
It's kinda funny how these trucks handle an old battery. One day it's fine, the next it's toast. I went through that a couple of weeks ago. Loaded the kiddo in the rig to go to daycare, turn the key and nothing. The previous day it started right up without hesitation. $100 at the local Autozone for a new one
Old Jul 17, 2010 | 02:01 PM
2002sport's Avatar
2002sport
I thought mine was a battery, all was fine, went inside, came back out, barley started, that's when things went haywire. It quit me before I got home. I put in a different battery, not new, but one out of my old car. Everything fine for a day, then I started losing charge again. $200 at NAPa for an alternator fixed it.
Old Jul 20, 2010 | 09:13 PM
pidaster's Avatar
pidaster
What?
jruggles
Apr 20, 2014 12:42 PM
JOHN2001
Jul 18, 2013 10:59 AM
chucky0094
Aug 31, 2008 08:34 PM
Vijay
17
Oct 6, 2006 07:04 PM
sawdaddy5
Jul 6, 2006 10:27 AM
