stc fitting installed on a pump.
Old Aug 30, 2010 | 10:05 AM
Benchwrench's Avatar
Benchwrench
Originally Posted by m-chan68
4C3Z-9B246-F
is this still good for an '06 model?
are all the gaskets in the kit also included?
can the intake manifold be left alone?
Is this an easy procedure?
Old Aug 30, 2010 | 10:09 AM
m-chan68's Avatar
m-chan68
Yes, yes and yes to the first three questions. In answer to your last question, easy is a relative term dependent upon your wrenching ability.
Old Aug 30, 2010 | 01:14 PM
Benchwrench
regarding the STC fitting update,
Do you think this should be done as only as necessary/failure or as preventative measure?
Old Aug 30, 2010 | 05:58 PM
cheezit's Avatar
cheezit
preventative measure.
even if / whenb the new style fails you atleast dont wind up with a broken rear cover and a cracked branch tube.
Old Aug 30, 2010 | 06:21 PM
sammy77's Avatar
sammy77
Gonna tackle this task in a couple weeks. Also I need to get an IPR socket are there 2 different sizes for an 05?? Thanks...
Old Aug 30, 2010 | 06:27 PM
cheezit's Avatar
cheezit
nope there all the same size from 03 and up. I have a socket that I use when the turbo is on. I use a 36mm wrench that I cut in half when the turbo is off.
Old Aug 30, 2010 | 06:46 PM
sammy77's Avatar
sammy77
Ok, bring that, a 12pk, large cheese pizza, and that spare turbo you're kickin around in the garage. I'll see you Saturday at 10, you know the place...
Old Aug 30, 2010 | 08:00 PM
jetact's Avatar
jetact
I dont need any special wrench if the engine is out on the floor do I? I bought the SCT update and the IPR. I figured if tearing it all apart be preventative. Dam they are not cheap.
Old Aug 30, 2010 | 08:18 PM
cheezit's Avatar
cheezit
just soemthing to take it out with. nothing special required if you can reach it.
Old Aug 30, 2010 | 08:24 PM
jetact's Avatar
jetact
Good. I can see it right in front of me. Havent opend up the cover to see the sct yet though. Dam this is getting expensive.
Old Aug 30, 2010 | 09:18 PM
bismic's Avatar
bismic
Where are you buying the parts from? There are a few places that are MUCH cheaper than others. Also, I found a cheap IPR socket. Shopping around really can pay big dividends!
Old Aug 30, 2010 | 09:21 PM
jetact's Avatar
jetact
I have most all of my parts but I am finding more that I need as I go along. I was just on Ed the parts guy site looking at glow plugs as I have at least two that dont look very good.
Old Aug 30, 2010 | 09:30 PM
  #28
bismic's Avatar
bismic
Ed and Tousley Ford are two good places to buy parts!
Old Aug 30, 2010 | 10:04 PM
  #29
sammy77's Avatar
sammy77
IPR sockets are goin for $55-$70 Anyplace cheaper than that? Thanks
Old Aug 30, 2010 | 10:15 PM
  #30
bismic's Avatar
bismic
$55 is about right.
Welcome to Handsontools.com - Auto Mechanic & Body Shop Tools & Equipment
Here is one for $53
http://www.antarespro.com/3460990-it...16d313d314d309
I forgot I had this place bookmarked (IPR socket for $49):
http://www.sjdiscounttools.com/otc6765.html
and this for $42:
http://www.ntxtools.com/network-tool.../OTC-6765.html
Some time back I bought a tool from these guys:
http://tools.spx.usatoolwarehouse.co...el-tools--list
