bad injector ?
Old Jul 14, 2010 | 06:44 PM
gb'sfx4's Avatar
gb'sfx4
old enough to know better
bad injector ?
at idle the rpm's go up & down 12- 15 rpm, you can't hear or feel it , just see it on the insight . If I hit the high idle it does not fluctuate as bad, just a couple of rpm. no codes or smoke other than a small puff on start up. about 2000 m. on filters & mobil 5/40 syn.
Old Jul 14, 2010 | 07:14 PM
cheezit's Avatar
cheezit
12-15 rpm at idle is good. thats the truck changing fuel flow to self correct and provide the smoothist possible idle it can. the engine as with all fuel injected engines gas or diesel will always drive cyclinders rich to lean or lean to reach this is for the above stated reason along with with the fact it helps the engine self detect isses with most of the sensors and modules.
Iss ues with a hundred rpm are greater may be a concern
Old Jul 14, 2010 | 07:33 PM
gb'sfx4's Avatar
gb'sfx4
good to know , thanx as always
894X4shorty
Jul 16, 2014 05:57 PM
79broncojosh
Feb 4, 2011 11:28 AM
Iceman_AKA_Ford guy
Aug 6, 2010 05:25 PM
kemerick
1983 - 2012 Ranger & B-Series
Jul 14, 2009 03:17 PM
tolliewolly
Jan 23, 2008 09:55 PM
