erratic idle...
Old Mar 20, 2009 | 08:08 PM
kemerick's Avatar
kemerick
erratic idle...
My EFI Ranger has an erratic idle. It is inconsistent and mostly does it when idling and when I give it just a little bit of gas, like 2-300 RPM more than idle. It will rev itself up 1-300 RPM back and forth between normal RPM and the higher.
It just had the timing chain replaced and the head machined as the timing chain slipped and somehow caused coolant to **** its way out into the oil. The mechanic did a bad job of explaining and said it was fixed. With that solved the new problem arose... the inconsistent idle.
If I ignore the recent work, could it just be throttle body or vacuum hoses needing a refresh?
Old Mar 20, 2009 | 08:59 PM
michigan66's Avatar
michigan66
What year & what engine for your Ranger?
Old Mar 21, 2009 | 07:47 AM
tomw's Avatar
tomw
Quote:"the timing chain slipped and somehow caused coolant to **** its way out into the oil."
If I heard that from a mechanic, I doubt I'd be utilizing his/her services. The timing chain could have allowed the valves to impact the tops of the pistons, but unless the engine was running at a pretty good clip, and broke the valve into pieces that penetrated the cylinder walls or head, there is no way a slipped timing chain can cause coolant to mix with the oil.
If coolant mixed with oil, it could have ruined the bearings, as it forms a goo that doesn't lube too well, and plugs oil passages and pickup screens.
Your idle problem may be IAC, leak, fuel pressure, injectors, filter, air filter, spark plugs, plug wires, coil, distribulator [we don't know vintage] and probably 183281615278+/-4 things. Yeah, I made that number up.
Spark, air and fuel. Remember those things, they will be of importance later in the game...
tom
Old Mar 22, 2009 | 08:47 AM
pawpaw's Avatar
pawpaw
On the idle problem, maybe look to the IAC, or maybe a unmetered vacuum leak that the IAC can't compensate for.
Dryrotted vacuum lines, clogged up stuck open PCV valve, leaking vapor recovery system hoses, leaking vacuum bake booster diagphragm, are good vacuum leak suspects.
Sounds like your so called mechanic was pulling your leg, or was trying to run one by you & if so, maybe not darken his door again!!!!
Old Jul 14, 2009 | 03:17 PM
lurchy98's Avatar
lurchy98
Idles fast...then dies!
Sorry, I added this to the wrong post.
frikosz
2009 - 2014 F150
16
Oct 26, 2023 07:19 PM
BigDoug
Mar 31, 2015 10:57 AM
Lead Head
May 31, 2014 01:04 PM
dreamison
Mar 22, 2011 11:10 AM
tlk401
2.6, 2.8, 2.9, 4.0 & SOHC 4.0 V6
Sep 25, 2006 08:12 AM
