So I decided not to forgo the work of chaniging out cabs from my 150 to 250. The cab is solid besides the floor pans, so I ordered new ones from LMC. However, since placing the order LMC called me back and said they had to charge me more for shipping because it was a bulky item. They wanted $180.00 per pan to ship to Alaska!!! So I told them to keep them I guess I will be fabricating my own...should be simple enough. So I cut the passenger pan out so far and plan on finishing cutting thw drivers pan and rear floor tonight or tommorrow. I do have a question pertaining to installing the re sliding window. Should I use some type of sealant on the seal when I reinstall the window or is the seal enough? I'm also switching beds and am having trouble like everyone else is with the front two carriage bolts!! Sprayed some lubricant on them and waiting now.
I reinstalled my rear slider last week, used nothing more than the stock 1994 gasket! still no leak, and its been raining here for past 2 days on and off!
As for the floor pans, just grap some decent sheet metal and go to town. I saw a thread on here not too long ago where they used 1/8 steel tread plate. Kinda overkill but he used what he had, and it will prolly outlast the rest of the truck!
Those front carriage bolts can be a real pain ! grap vise grips and your torch. heat the bolt till its got a nice glow, clamp the vise grips on the metal clip where the bolt goes through, jump in bed with a good torx socket and a impact. A helper is handy to keep from jumping back and forth. If you cant get them to come out, cut them out with the torch and buy new bolts and nuts!
dude, what are you talking about?
carriage bolts= NOT TORX
Dents= No torx. no "clips."
Dents= carriage bolts with a square upper shank drop through square holes in bed floor and round holes in frame before being capped with a nut. Nut rusts to bolt. End of game. There is no way to get a pair of pliers or anything else on the bolt heads, although you can try using a cut off wheel to slot them for a standard screwdriver. This isn't going to help much when they are stuck though. Spray em with a lubricant, hit them with a breaker bar, if they don't break loose or if they spin the square outta the bed holes, use the cut off to zip them off.
Hi guys, trying to button down my bed, and the bolt that was in the left very front hole was so rusted when I got the bed that I had to cut it off. It was rounded like a carriage bolt, but it had a phillips head, and it then screwed into a speed nut which clipped over the frame. Having a heck of a time finding either the bolt or the speed nut. Anyone know where I might be able to find these? Thanks.
Originally Posted by Joseph69
Stealership, they used these bolts on newer trucks. Im guessing you have a SuperCab, had the same issue. Look for a 90s supercab front bed bolt. Took a while to find.
Trust me, special to only the SuperCabs, dealership, about 8 or 9 bucks for the two bolts, the others are standard.
use some road signs for floor pans and if the rear seal is installed correctly with the window there should never be an adhesive sealant
According to the Ford Service books...
Apply 1/4 bead of sealant 4" (8" total) on each side of the seam where the "B" pillar and roof of the cab meet. This is to prevent water from getting in between the seam and the seal.
My 77 had no clips. I cut the heads off and pounded them through no problem. the heads were pretty well rusted but didnt look any different than the other bolts.
Whichever style of carriage bolts you have, you will probably have to grind them off with a cutting wheel as I did. When I replaced the left front carriage bolt, I went to the dealership and got a newer pickup carriage bolt that had a torx head on it, and a speed nut which clips over the frame for the bolt to go into. The space between the front tank and the frame rail makes a torx or phillips head carriage bolt and speed nut very handy when replacing these, especially if doing it by yourself as I was. A tip, I soaked all the bolts and nuts in a plastic bowl with CLR full strength and let it sit overnight. Most of the rust came off, and what didn't, I used my handheld angle grinder and a wire brush and knocked the rest of the rust off with that, then I primered and painted the bolts and nuts and then when putting them back together, I used anti seize compound on the threads.
Thanks for the tips. Yea mine has the phillips heads for the front two carriage bolts. I will try to heat them up and see what that yields. As for the pans I'm going to pick up some scrap metal tommorrow.
The back glass will seal without the adhesive if installed right. I'v had five of the 79 models and none were sealed and non leaked. They were used in my buisiness for several years. I would put some adhesive in not to stop leaks but to help prevent somebody from removing it easy. If the glass has a metal frame around it like the slider ones do , I can remove it in less than three minutes and make no noise,scratch no paint and break no glass. So security is the only reason I would do it. As far as the bolts , grind or torch them off.
Then why does the Ford Service books say to add sealant. Look at post #7 for a scan of the page in question. It even explains why to do it. It's to Keep water from getting between the roof and "B" pillar seams and the seal. If water gets trapped in there it can cause cab rot in the corners. The window may not leak but water can still find it's way in there and be trapped. Seen it before in the wreckers.
Don't use any sealant at all if you want, however it is against the advise of the Ford Service manuals.
Yea it didn't take me long to remove the original window and its the first one I ever took out. I guess security wasn't the main concern back when they were built. Thanks for all of the advice on this. Hopefully I can get this truck all back together and the interior repainted before the snow flies!!
