backup camera install
Old Jul 13, 2010 | 09:36 PM
pimpstang18's Avatar
pimpstang18
07 F150 Lariat SCREW.
just got a new nav system with backup camera. was wondering where to run the wire for the camera on this truck.
haven't actually looked at it yet but i'm thinking of running it along the undercarriage and up through a grommet in the firewall, is this the best way to do it or does anyone else have an easier way that would use less wire? because i think i'll have to extend it if i do that.
Old Jul 14, 2010 | 05:35 PM
pimpstang18
Just as a reference if anyone was wondering I ran it along the main harness down the driver side of the frame. The harness enters the cab through a grommet under the drivers door sill, you can run the camera right up the side of the grommet. The length was perfect I didn't even need to extend the wire.
Also the correct wire on this truck to tap into for the reverse signal (to get the camera to come up when you put it in R) is the bright grn with yellow stripe, i tapped into it near where the harness connects under the driver kickpanel (its the grey harness on the bottom when you take the kick panel out.
overall pretty easy install, also did my nav, bluetooth, and steering wheel controls today.
Old Jul 19, 2010 | 10:33 PM
elite64a's Avatar
elite64a
hey brotha post some pics this is something I'd like to do in my 05. How much did it all cost? was it a OEM Nav or aftermarket?
Old Oct 3, 2010 | 11:55 AM
jamrock's Avatar
jamrock
Hi, do you know if its the same colour for a 99 f150. I'm installing a boyo vtl420, and i need to find the reverse signal wire behind dash or somewhere around that. Any help?
TheHern
Dec 19, 2017 12:52 AM
scimring
6.7L Power Stroke Diesel
Oct 28, 2016 10:04 AM
afhanson72
May 26, 2016 01:58 PM
smoky_diesel
Jan 13, 2014 03:23 PM
ccllud
Mar 5, 2013 05:52 AM
