problems....EGR delete?? Questions
Old Jul 15, 2010 | 03:44 PM
tex25025's Avatar
tex25025
Originally Posted by Z06MAN
Going to check the fuel pressure next, what should it be? Do I need to pick up a gauge for this or will a program like Auto Enginuity or a programmer show the pressure?
That'll have to be done with a gauge. AE pulls from the PIDs in the computer and there isn't one for Fuel PSI on ours.
Old Jul 15, 2010 | 08:42 PM
Z06MAN's Avatar
Z06MAN
What kind of pressure should I be running?
Old Jul 15, 2010 | 09:14 PM
tex25025's Avatar
tex25025
You don't want to see less the 45 PSI. Mine is running at 60 PSI, but stock it should be around 52-53 PSI I do believe. I never had the gauge on my truck when it was putting out stock pressure, so I'm a little fuzzy on where they normally are, however, that 45 PSI is a threshold. I wouldn't even like to see below that even if it's only at WOT.
Old Jul 16, 2010 | 11:17 AM
Z06MAN's Avatar
Z06MAN
Okay I'll pick up a gauge and check it. Where is the best place to check it at? Or I guess where is the test fitting located?
Old Jul 16, 2010 | 11:19 AM
Z06MAN's Avatar
Z06MAN
Where is the best place to buy a test gauge?
Old Jul 27, 2010 | 08:49 PM
Z06MAN's Avatar
Z06MAN
okay finally got time to check the fuel pressure. I'm running between 58-62 during normal driving and it drops to 52-53 under full throttle.
I timed it from a dead stop today, punched it at a stoplight and it took 3.6 seconds before it started to build boost. Is that normal? That seems really slow.
Old Jul 27, 2010 | 10:46 PM
tex25025's Avatar
tex25025
You will have lag if you just stomp on it from a dead stop. Now I've never timed it when I had the stock turbo, so I don't know if that exact time is normal(I don't see it being unreasonable though, alot of variables that will play into how quickly your truck built boost), but I can tell you it's far better to ease in the throttle then it is to just try to build it all at once from a dead stop.
Old Jul 27, 2010 | 10:58 PM
jetact's Avatar
jetact
Originally Posted by tex25025
Well, since you are wanting to disable the EGR sensor, you'll need to get a custom tuner. No ifs ands or buts about it. SCT will do fine by you if you are on a budget. Get the X3 though. You can have them just do 1 tune for you and that would be to disable the EGR sensor. They don't have to do anything else. The joys of custom tuning.
I wouldn't do a tuner for fuel economy. You might see gains, you might not, you might even see losses. It'll take a lot of miles(and I do mean a lot) to break even on doing a tuner for fuel economy reasons.
Tex,
You say the SCT if on a budget. What if I threw the budget out the window. What tuner would you suggest if I also needed an EGR delete written in to a tune.
raebear1
Aug 22, 2015 12:20 PM
IHateCommieCars
Aug 4, 2014 11:06 PM
Lloydable
24
Jul 29, 2014 09:11 AM
madhatt
Mar 13, 2014 05:05 PM
twlyons1
May 17, 2012 07:13 AM
