Drain plug installation?
Old Feb 10, 2003 | 02:34 PM
bigric's Avatar
bigric
I'm considering installing a drain plug in my E4OD pan (and others), and was wondering if anybody had tried this or had any thoughts on it. It seems like a no-brainer: drill a hole, install one of those self-tapping drain plugs like you get for stripped oil pans. The only problem that I can think of is clearance--you don't want to install a plug that is so long that it makes contact with anything inside the transmission. It seems like this would make servicing the tranny a lot easier down the road.
Old Feb 10, 2003 | 06:53 PM
GeneStoner's Avatar
GeneStoner
Next time you change the filter in your trans, necessitating the removal of the pan, do it then.
This way, you can eyeball any clearance issues, clean out any metal shavings, and figure out where the best location would be that allows the most fluid to escape (if you just drill a hole in the bottom of the pan and stuff the plug in there, the plug will extend up into the pan far enough that any old fluid below it's opening will not drain out).
Old Feb 11, 2003 | 10:13 AM
jim henderson's Avatar
jim henderson
Also keep an eye towards not letting the plug hang down where it can snag on something in the orad or get hit with that unlucky big rock. You don't want to drain your tranny at the wrong time.
Most people prefer to put the plug towards the back side of the pan for the above reasons.
Some of the tranny pans I have seen, have a indented place in the pan for a plug. That is probably the ideal place to put one.
Do this like the guy said, during an atf change, that way you can see what might interfere. On smaller pans there are not a lot of places that won't interfere. On bigger pans, who cares?
Good Luck,
Jim Henderson
Old Feb 11, 2003 | 10:42 AM
John Barleycorn's Avatar
John Barleycorn
I put drain plugs on every transmission I've owned. I cant believe they don't come that way from the factory.
You dont want to just drill and tap the pan, though. This will definately strip the threads. I just buy a drain plug kit at summitracing.com for about $7.
No matter how careful I am, it looks like I jumped into a pool of tranny fluid every time I drop a pan without a drain plug.
-J
Old Feb 11, 2003 | 12:14 PM
03f150man's Avatar
03f150man
have you guys installed a drain plug in a torque converter. My 97f150 has factory installed converter drain plug but from what i understand the 2004 and subsequent ford f150's will come without a converter drain.
Old Feb 11, 2003 | 05:15 PM
AggiePSD's Avatar
AggiePSD
Putting a plug in a converter not made for it might throw things out of balance. Not sure, but it might be a possibility.
Old Feb 12, 2003 | 04:17 AM
BlueOvalFitter's Avatar
BlueOvalFitter
Go to any good parts store and ask for a B&M drain plug kit.Under 8.00 and you dont have to wait for it in the mail!
Old Feb 12, 2003 | 06:29 AM
03f150man's Avatar
03f150man
Fatf150, have seen drain plug kits for the pan but are you saying kits are also available for the torque converter.
Old Feb 12, 2003 | 03:50 PM
BlueOvalFitter
150Man,no,just for the pan.You will unbalance the converter if you do it yourself.
SmittyD
Bronco II
Apr 3, 2014 08:43 PM
FordTruckEnthusaist
Nov 27, 2012 09:14 PM
alvald83
Oct 5, 2012 11:35 PM
Pirate16
General Automotive Discussion
Nov 2, 2004 06:43 PM
amckeag65
Aug 20, 2002 08:29 PM
