Sponsored by: Real Truck
Dash Lights issue - 2011 F250
Old Oct 12, 2010 | 10:58 AM
  #31
iamsuperdan's Avatar
iamsuperdan
Originally Posted by ruschejj
I'm glad you didn't take my post to be hateful. Just so you know, I have been messing with my dash lights and here is what I find. My instrument cluster lights are always on, day or night, brightness is adjusted with the dimmer thing. As far as lighting the radio/HVAC/etc... I don't know how that is controlled and those things are not illuminated during the day.
I agree that the dimmer switch thing is strange, much prefer the dial type potentiometer. And, my lights are always on "Auto". I just like it that way.
Good luck with your 150. My father is looking into getting one when the new engines are available too. I am looking forward to checking it out.
This is bizarre! my dash lights rarely came on, yours are always on, and the ones at the dealer are on when you want them to be on. Something weird in the Ford electrical department. Maybe those partying Dodge employees have friends at Ford!
My F150 has been awesome. Put 1500km on it this past weekend, averaged somewhere around 18mpg. Can't wait for my EcoBoost in January!
Old Oct 12, 2010 | 04:29 PM
  #32
DBags's Avatar
DBags
My lights are on as well but I found a piece of paper that I kept in the storage place on top of the dash that was covering up the sensor that is located in the middle of your dash near your window.
Old Oct 14, 2010 | 07:55 PM
  #33
Chuck Woolery's Avatar
Chuck Woolery
What cluster do you have, standard or the LCD message center? I'm assuming you have the LCD message center with the fancy screen cause that's the gauge cluster we have in the work truck and it operates exactly as you describe, aka gauge lights are always on.
Well I got the truck back from the dealer. They told me the same thing that it's how the truck is designed and they can't fix nor change it. They did keep it overnight to see if there was anything they could do, but couldn't come up with anything. I believe them that they're trying to help, but there's not a lot they can do. I did tell them that it's BS that two trucks of the exact same model with different gauge clusters operate differently. I told them that it would be 10x safer if the gauge lights just stayed on like the trucks with the LCD screen as the gauges themselves are hard to read in daylight without the backlighting.
They did print off this blurb from the technical service manual to explain to me the operation of the dimmer switch and the autolamps.
The dimmable illumination is used to provide backlighting to the IPC, switches, and control components when the parking lamps are on. The level of intensity is adjustable by pressing the instrument panel dimmer switch either up to increase intensity or down to decrease intensity.
The dimmable switches and components are illuminated when the parking lamps are ON. The instrument panel dimmer switch is a double detent rocker switch used to control all dimmable interior illuminated components, and to control the courtesy lamps. The first up detent increases dimmable backlighting intensity. The first down detent decreases dimmable backlighting intensity. The second up detent turns the courtesy lamps on. The second down detent turns the courtesy lamps off (allowing other features to control the courtesy lamps).
On vehicles equipped with autolamps, if the exterior lamps are activated during daytime sunload conditions, the message center illumination remains at full intensity and does not dim from the instrument panel dimmer switch during this condition. If the vehicle travels under a bridge or a tunnel, the low level of ambient light causes the illumination level of the message center to change to the level set by the instrument panel dimmer switch. The message center illumination changes back to full intensity when the intense ambient light is restored.
I interpret the last paragraph to say that the auotlamps do NOT control the gauge lights, only the message center (the MPG, odometer, radio, etc...). In that case the gauge lights should always be on when the lights are turned on either with the autolamps or by manually turning them on. Unfortunately for my truck (and it appears to be others with the standard cluster) that the autolamp sensor is controlling the gauge lights as well. It's so bad, in fact, that when I turn the head lights on during sunlight the needle actually gets really dim to the point of not being able to see it. This is dangerous in the early morning and early evening (dawn and dusk) when you need lights, yet the sun is still out somewhat. It's actually impossible to see the gauges during this time.
Either way I don't think there's anything the dealer can do. I already told them I don't blame them for the problem and that I appreciate them looking at it, but that I'm going to write a letter/e-mail to Ford explaining my displeasure with how the system works and ask for a fix. He told me it's not right that I should have to do that, and that they did everything they could, but it's primarily the design.
Old Oct 14, 2010 | 07:58 PM
  #34
Chuck Woolery
I tested this as well tonight (put a piece of paper over the sensor) and it does work by turning on the lights when in autolamp (takes a couple of seconds to work if the truck is already running). I'll have to try it during manual control of the lights to see if it leaves the gauge lights on. If this works the electrical tape over the sensor will work, but unfortunately it means completely disabling the autolamp feature, not forgetting having to "rig" a brand new vehicle to quit being stupid.
Old May 15, 2019 | 10:49 AM
  #35
geekwithoutacause's Avatar
geekwithoutacause
Damn.. This is an old thread but I have this exact same issue !
Did any of you figure out the issue /solved it ?
My 2014 has the issue too. I was messing with it yesterday. During the day I could not get the dash lights to turn on no matter what. Then later that day when the daylight started to fade all of a sudden the dash lights worked again. So at least they work at night. But still, they SHOULD work in the morning too when it's light but still a tad dark to see the gauges... and they won't work no matter what.
I am wondering if it's a software issue.?
Old May 20, 2019 | 07:42 PM
  #36
geekwithoutacause
welll...
Took it to a dealer who took a look at it. Didn't charge me. Came back with the same answer; This is 'as designed' and they won't fix it.
It's a software bug plain and simple. Oh well. I've disabled the auto sensing light in Forscan. This way it works as it should.
The other option is to cover the light sensor with some tape. Then it will work as designed but you're auto lights will always be on.
oh well. Stupid design.
Badfordv10
Mar 22, 2017 04:59 PM
87thhunter
Oct 27, 2016 03:41 PM
1Austin112
May 10, 2016 05:11 PM
ligito
Dec 29, 2015 11:07 AM
csoddy
Sep 30, 2015 09:50 AM
