Caster Bushings
Old Jul 12, 2010 | 10:10 PM
1fastroadking's Avatar
1fastroadking
Caster Bushings
Are the stock caster/camber bushings that Ford uses marked with the degree of offset or correction? I see what looks like numbers partially covered by the ball joint nut but I can not tell if they are a part number that needs to be deciphered or the offset in degrees. <?xml:namespace prefix = o ns = "urn:schemas-microsoft-comfficeffice" /><o></o>
<o></o>
Thanks<o></o>
<o></o>
Richard<o></o>
Old Jul 13, 2010 | 06:41 PM
anotherfordguy's Avatar
anotherfordguy
Remove the nut for the ball joint and the degree amount should be on there. If its hard to read use a wire brush to clean the markings. The location of the split will tell u if the correction is positive or negative.
dssocialwrk
Nov 30, 2018 04:55 AM
Texas 6.0
Feb 14, 2012 07:04 PM
smkf100
Oct 12, 2011 04:29 PM
rjlabonte
6.4L Power Stroke Diesel
Oct 23, 2010 08:40 PM
