ARP head bolts
Old Jul 12, 2010 | 09:57 PM
mxnick824's Avatar
mxnick824
ARP head bolts
Wondering if anyone out there has heard of anyone changing the headbolts on the 6.0 with out doing a "head job". changing them one at a time i guess?
Old Jul 12, 2010 | 10:03 PM
texans's Avatar
texans
It has been done, but not recomended. Why spend all that time to get to it and not spend the couple hunderd more to do the job right the first time. Take the heads off have them checked for cracks and flatness. Install new hg and not worry about it again.
Old Jul 12, 2010 | 10:10 PM
John Diem's Avatar
John Diem
Head STUDS
Lots of posts on doing studs without lifting cab and installing one at a time . When I get enough money saved that's how I will do mine lot of guys will tell you not to do it this way but I don't see any reason to destroy a good seal and gasket. Good luck John
Old Jul 12, 2010 | 10:11 PM
Headviking's Avatar
Headviking
That will explain the gin on my face....and my wife thinks it's gas. Have the head sent out and checked. It's worth the money. I can sleep at night knowing that the heads on my truck are flat and without cracks. ARPs and a new HG. It'll give you that warm fuzzy feeling inside.
Old Jul 13, 2010 | 11:44 AM
rickatic's Avatar
rickatic
I think the risk is somewhat tied to miles on the truck. In Johns case, he has extremely low miles.
Old Jul 13, 2010 | 05:11 PM
tex25025's Avatar
tex25025
If you are 100% sure that you have zero problems then it might not be a bad idea to just do them one at a time. Would I do it that way, no, but the truck isn't mine.
Now if you are doing heads because they need to be done or you are unsure if you heads are still good, then it would behoove you to do it all the first time, otherwise, you will eventually have to tear back into it to fix it yet again. Contrary to popular belief, the mere fact of having ARPs in the truck doesn't mean that you can't have head issues again unless the installation was done correctly the first time. This is coming from someone that had to do the job twice.
Old Jul 13, 2010 | 07:14 PM
cheezit's Avatar
cheezit
hehehe ya all but the one on the left head lower corner that ones fun.
Old Jul 13, 2010 | 07:38 PM
mxnick824's Avatar
mxnick824
yea i would never do a half head job if i had problems. i have no issues with the truck at all. i just want to feel better about putting a tuner on it.im not a hp hungry guy. i just have a 10,000lb camper and would like some added juice when pulling and stopping.
Old Jul 13, 2010 | 07:50 PM
jetact's Avatar
jetact
Tex, Were you able to do the ARP head studs without lifting the cab? Did you use Ford head gaskets or Black Onyx?
Old Jul 13, 2010 | 07:56 PM
rickatic's Avatar
rickatic
Five minutes using an air chisel with a hammer bit makes short work of getting clearance on the drivers side. Passenger side you need to pull the one side of the hvac box. Cheezit is the expert but my nephew is getting pretty good. Amazing what you can do with a few rubber bands and sections of rubber tubing.
Old Jul 13, 2010 | 08:02 PM
rickatic's Avatar
rickatic
I am not Tex, but I stayed at a Holiday Inn once. We had the heads off my 04 truck 3 times. We had the engine out once. We never raised the cab. I have used both head gasket types with equal success. When my nephew does a job now, he does remove the front end. He can get it out of his way in an hour and it does make it much easier.
Old Jul 13, 2010 | 08:24 PM
tex25025's Avatar
tex25025
We had access to a lift, so we used it. Some might think it's extra effort and time that doesn't need to be spend. But it made it a whole lot easier doing the other stuff that I was doing as well.
I used Ford gaskets. To my knowledge the only difference between Ford's and Black Onyx is the amount of sealant that is on them. If I recall correctly, Ford's just has it around the edges and around the cylinders, whereis with the Onyx it is all over. Other then that, I think they are identical.
I have heard good things about the Onyx though, Ford's are still good enough unless you are wanting to push some major HP.
Old Jul 13, 2010 | 08:26 PM
jetact's Avatar
jetact
Ok now that was funny. Thanks for the insite. Would you use one head gasket over the other?
Old Jul 13, 2010 | 09:00 PM
rickatic's Avatar
rickatic
I used the Black onyx's the last time. You can buy them from Northern Auto Parts in Sioux City, Ia for around $100 and no head bolts to throw away.
tk1251k
Aerostar
46
May 31, 2014 10:28 AM
extra
13
Feb 28, 2014 05:26 PM
croatoan
1997 - 2003 F150
Oct 12, 2009 07:12 AM
bwep
2004 - 2008 F150
May 20, 2009 08:25 AM
TRIPLETS
18
Jun 13, 2006 08:13 PM
