Temporary Rise in Coolant Temperature
Old Jul 12, 2010 | 07:57 PM
hi-jacker's Avatar
hi-jacker
I was pulling a small single axle trailer up a long hill with my F350 diesel today and my Edge Insight monitor showed a coolant temperature of 288 degrees. The needle on the OEM dash gauge did not go up. After awhile the temp went down to 199 degrees which is pretty normal for summer.
Since my factory gauge didn't show a rise in temperature, I'm thinking the Edge Insight monitor was malfunctioning (unless an 80-degree rise in temperature doesn't register on the factory gauge). Anyone else ever experienced this? Thanks.
Old Jul 12, 2010 | 09:01 PM
bismic's Avatar
bismic
The dash temperature gauge is not very responsive - it is more like a switch. I sure would have thought it would have moved some if it were that high in reality though. I would think the only thing that would explain a spike like and then a dip back to normal (if it is real) would be a sticking thermostat.
Old Jul 12, 2010 | 10:08 PM
texans's Avatar
texans
When my egr cooler was going out I was pulling my 38' tt and my temps got up two 248 or so, the factory gauge did move to the red, but it didn't do so untill I hit the 248. It was showing normal the whole time untill I hit the 248. Then went from normal to max at once. That's why I say never go by the factory gauge.
Old Jul 12, 2010 | 10:12 PM
npccpartsman's Avatar
npccpartsman
That could very well be blown headgaskets too. Are you loosing coolant out of the overflow bottle??
Old Jul 12, 2010 | 10:14 PM
hi-jacker's Avatar
hi-jacker
I don't seem to be losing coolant, and there is no white smoke.
Old Jul 13, 2010 | 08:42 PM
texans's Avatar
texans
Did you hear the fan come on?
P.S everyone needs to vote in the diesel championship (for me of course) we can't let those idi guys beat out a 6.0. https://www.ford-trucks.com/forums/9...round-7-a.html
Old Jul 13, 2010 | 10:05 PM
cheezit's Avatar
cheezit
scott do I need to put up a pick of my truck?
back to the op there are a few threads going on this now, IMO you may have a head bolt issue.
JRD761
6.7L Power Stroke Diesel
Sep 24, 2015 11:05 AM
cabinman
Jun 18, 2014 01:56 PM
Utah Jake
Mar 22, 2014 05:45 PM
U235Fishin'
Feb 24, 2014 01:38 PM
ocboat
Sep 16, 2010 06:56 PM
