My new project. Pics!
Old Sep 4, 2010 | 09:25 PM
  #61
plgebbia's Avatar
plgebbia
Originally Posted by 427 fordman
That looks really good Ian. Job well done for sure.
Thanks, I hope I've covered most of the potential problems with it.
Did anyone have any thoughts on the up-pipe gaskets I used?
Old Sep 4, 2010 | 11:09 PM
  #62
oldbird1965's Avatar
oldbird1965
Those up pipe gaskets are suppose to work good I have heard.
Old Sep 5, 2010 | 05:55 PM
  #63
plgebbia's Avatar
plgebbia
Great! I only paid $5.40 for them, so if they work, that is really cheap!
Old Sep 8, 2010 | 09:01 PM
  #64
plgebbia's Avatar
plgebbia
I got the Diamond Eye downpipe today and got it installed. I will post some pics when I get a chance. On a side note, the Accelerator pedal is very touchy off idle. its like idle to 1200 rpm, any ideas what would cause this?
Old Sep 8, 2010 | 09:19 PM
  #65
fordpride's Avatar
fordpride
Could be a bad TPS
Old Sep 8, 2010 | 09:43 PM
  #66
chicagodragon's Avatar
chicagodragon
Mine used to be like that. Try bending out the tab for the IVS to make it release sooner
Old Sep 23, 2010 | 06:25 PM
  #67
plgebbia's Avatar
plgebbia
Well, I sold my truck and I am driving this one now.
I really like it, It is quieter and smoother in the cab, and it runs even better than my old truck. I still need to clean and wax the paint, but I took a pic of it with the new tires, see what you think! (they are 285/75/16 Dayton Timberline A/T 10 ply)
Water temp gauge.
The other gauges
Old Sep 23, 2010 | 06:34 PM
  #68
427 fordman's Avatar
427 fordman
Looks good Ian. Nice gauges. I'm going to put my scan gauge where you put the water temp gauge. Is the dash hard to pull to get that gauge in there? Never had it out yet.
Old Sep 23, 2010 | 06:36 PM
  #69
Krisx125's Avatar
Krisx125
Ohhh how i miss my red interior.......Awesome job man!
Old Sep 23, 2010 | 06:45 PM
  #70
plgebbia's Avatar
plgebbia
It is not very hard to get off, you just have to be careful not to break anything.
1. pull out the headlight **** till it stops, then insert a small slotted screwdriver in the slot in the **** and pull the screwdriver and the **** toward you.
2. pry off the two pieces off trim on either side of the column, and remove the two 7mm screws.
3. Carefully pull the bezel toward you, there are several clips on the back side that can be fragile.
4. once it is unsnaped, unhook the wiring from the fuel tank switch and the wait to start area.
It's off!
Krisx125, the red interior is growing on me.....
Old Sep 23, 2010 | 07:39 PM
  #71
Brown Falcon's Avatar
Brown Falcon
Looks awesome Ian!
I have my trans temp on the dash there and putting my boost and pyro on the pillar.
Old Sep 25, 2010 | 09:57 PM
  #72
plgebbia's Avatar
plgebbia
Thanks Brownie! I really like that spot for a gauge, it is really easy to see.
I pulled my first load with it today, and it did really well. It was a trailer load of firewood that weighed about 8,000 pounds.
cashy52
46
Mar 8, 2021 12:17 AM
bad_habit_F350
16
Jun 2, 2020 10:54 PM
DRRXR
6.7L Power Stroke Diesel
314
Sep 1, 2016 09:42 PM
429unibody
1961 - 1963 F100 Unibody
215
Feb 3, 2015 10:10 AM
Aric43085
Jun 3, 2013 12:38 PM
