Sponsored by: Auxito
CV joint boot
Old Jul 10, 2010 | 07:20 AM
96f150's Avatar
96f150
CV joint boot
Is the outer cv joint boot replaceable? My drivers side outer boot has a small slit on it, just enough to leak a little grease every couple weeks..very small amount, and I was wondering if I can just replace the boot. I have seen those 2 piece boots and those r junk.
Thanks
Rich
Old Jul 10, 2010 | 09:32 PM
steve(ill)'s Avatar
steve(ill)
if the rubber is rotted, you got a problme. If it is just cut, i have cleaned it good with gas or alcohol on a rag, then put RTV in the splilt and pull the two halves together to glue it. Maybe rum a thin layer over the crack. Usse a tooth pick to push the RTV into the crack and drag over the top.
Old Jul 11, 2010 | 07:12 AM
96f150's Avatar
96f150
no, its def not rotted....I will try the rtv method...like I said, its very very small and it barely weeps it out.
Thanks
Rich
Old Jul 11, 2010 | 08:21 PM
Ultramagdan's Avatar
Ultramagdan
RTV is tough stuff and will fix your boot for a long time.
Stanislaw
Apr 15, 2015 10:02 AM
73fan
1997 - 2003 F150
Jul 9, 2014 08:17 PM
bunky383
Dec 8, 2013 01:22 PM
edub32
2004 - 2008 F150
Nov 1, 2011 03:40 AM
mikecox1
Apr 6, 2009 03:37 PM
