ENGINE HASNT RAN IN 3-4 YEARS, NEED TIPS BEFORE SATARTING IT
Old 07-08-2010, 11:45 PM
79 f-150 guy's Avatar
79 f-150 guy
79 f-150 guy is offline
THE PARTS TRUCK I BOUGHT HAS 59,000 ORIGIONAL MILES AND SPENT MOST OF IT'S LIFE UNDER A CARPORT.. IT HAS BEEN SITTING FOR ABOUT 10 YEARS AND WAS LAST RUN ABOUT 3-4 YEARS AGO.. I HEPED THE LAST OWNER GET IT GOING THAT TIME AND IT RAN GREAT, REAL SMOOTH.. NOW I WANNA GET HERE GOING AGAIN BEFORE I PULL THE ENGINE OUT FOR MY OTHER TRUCK...
MY MAIN QUESTION IS SHOULD I LUBRICATE THE CYLINDER WALLS FIRST AND IF SO WHAT SHOULD I USE.. ALSO SHOULD I PUT IN A NEW OIL PUNMP WHILE I HAVE THE CHANCE OR IS THE FACTORY ONE PROBLY FINE.
Old 07-09-2010, 12:20 AM
79FordBlake's Avatar
79FordBlake
79FordBlake is offline
You can remove the distributer and spin the oil pump with a drill to get it primed up. Then you can squirt some oil down in the cylinders and turn it over a couple times with spark plugs out. Then she should be good to fire up.
Old 07-09-2010, 12:24 AM
79 f-150 guy
ya i didnt think of pulling the distributer and doing that.. also should i use wd-40 or ?? for the cyliners. i was told by a freind to use wd-40.. i imagine the cylinder walls are a bit rusty from sitting.
Old 07-09-2010, 12:31 AM
CHELLIE's Avatar
CHELLIE
CHELLIE is offline
remove the old gasoline from the carb, it has turned to varnish, drain the gas tank, the gas is now varnish, flush the fuel lines, replace the fuel filter, use some marvell mystery oil in the cylinders, dont turn the carb upside down if you remove it from the truck, unless your going to rebuild it, sedement will plug up all the ports, remove a lower screw from diagphram, or an accell diaphram to get the gas out if its still a liquid and has not dried up in the carb. hope that helps, Chellie
Old 07-09-2010, 12:36 AM
79 f-150 guy
thanks for the help. thats about all i needed to know, i'll use marvell's mystery oil in the cylinders..
as for everything else, i'm gonna swap it over to a 4v setup and run new fuel lines and a new tank.. just needed to know what tube put in the cylinders to free them up.. thanks
Old 07-09-2010, 12:42 AM
79FordBlake
That is good advice but if he is going to pull this engine and put it in another truck I wouldnt fool with all that flushing fuel lines stuff. Clean the carb up some and then hook it up to a gallon jug and let it gravity feed to carb. I've done it many times on old clunkers that have been sittin in fence rows longer than I been alive.
Will the engine make a complete revolution by hand? If so its probably not rusted real bad. Id just get an oil can and pump a few squirts in each hole.
Change the oil after a short runtime.
Old 07-09-2010, 05:03 AM
hasteranger's Avatar
hasteranger
hasteranger is offline
my truck had sat for 6 years, "ran when parked."
I put 5 gallons of fresh gas in the tank, poured fresh gas into the carb, squirted a tiny squirt of starting fluid into the intake of the carb, pulled off the air cleaner, pulled all 8 spark plugs and gave each cyl 2 squirts of 5w30 from an oiler, and put new spark plugs in. cranked for like 10 seconds before turning over, smoking from the oil, and then running just fine.
Old 07-09-2010, 09:22 AM
dynamic's Avatar
dynamic
dynamic is offline
Ive done this both ways mentioned. Either way will work but seeing that you are removing the engine I would pull the line from the fuel pump and go the gas jug method!
Old 07-09-2010, 09:25 AM
704 dentside man's Avatar
704 dentside man
704 dentside man is offline
I'd go this route. Typically I add a little stabil to gas though. And instead of engine oil, I use Type F squirted in to the cylinders. For the first 1000 miles or so, I'll use a quart of Type F in the oil as well.
9000_red
10-10-2015 06:49 AM
Bkq15
1999 to 2016 Super Duty
08-24-2015 11:26 PM
Athanasius
12-28-2013 07:08 AM
CPL. Chaz
12-19-2012 04:53 PM
mike L
09-14-2004 04:13 PM
Quick Reply: ENGINE HASNT RAN IN 3-4 YEARS, NEED TIPS BEFORE SATARTING IT
