428 TROUBLES
Last Friday she started smoking out of the right bank. Didn't run any different just smoke when you first start her up. While driving no noticable smoke. Come to a stop for a minute or two and she starts smoking again.
Then I started her up on Sunday morning I hear this distinct rap in the right bank.
Question? Sticky lifter? Bad valve? Worse?
The first time I gassed her up I went to mobil and put in high test (as directed by the previous owner ) 10:5 - 1 compression. She hard started and would diesel when I shut her down unless I did so in gear. Put some octane booster in her and she ran better.
Next time I filled up and she ran fine. No booster.
Filled up again at a different mobil and she started doing the same thing. Then the smoking started and the nasty rap I'm hearing now.
So, any educated guesses at what I'm looking at? My experience tells me it's a bad lifter but so many variables are involved.
It doesn't seem to run any different but I don't want to run it anymore until I have some more knowledge.
I was tempted to pull the right valve cover and dump Kerosene down the head and let her sit. Drain her and then change the oil and try firing her up again. But again, I don't want to create more problems.
I did that with my I6 300 in my 65 when I started getting some rapping and it cleared right up. I didn't really care about that engine because it was tired and used oil. This one is a different matter.
Anything you guys can give for advice would be great. Thanks, Todd.
The smoke could be something simple like a bad intake gasket, but that and the "rapping" doesn't sound good if they are related.
I'm going to pull the valve cover this weekend. Hope I'm wrong.
Also, if the two are related what guess would you venture? If I don't find any obvious symptoms in the valve train what do you think?
I don't care if your right or wrong so don't worry about giving me information thinking I will be upset if it isn't what you suspect because I need to do work on it ( obviously ) so any good knowledge will help me to determine what I will be looking at. Thanks bud, Todd.
What color is the smoke? White blue or black?
Could be coolant (head gasket/cracked head) causing it to hydrolock and "rap" and blow WHITE smoke. Could be gas from a leaky carb getting down into one cylinder, causing hydrolock and the rap and BLACK smoke.
Or, a valve spring or keeper broke, dropped the valve, cracked the piston, and the oil is burning off, making BLUE smoke.
"She hard started" - hard to crank over, or cranked for a while and didn't fire right away?
What color is the smoke? White blue or black? WHITE, maybe blue but if blue very light.
Maybe I will pull the valve cover tonight after work, but it is so friggin hot and humid in my neck of the woods right now I don't relish the idea of doing much of anything but you have me motivated now. Have to see how lovely it is when I leave work.
So I take it out of the possible options you mentioned, it sucking a valve is the worst?
As a side note she is clean as a whistle ( no sludge ). Looked like a brand new FE under the valve cover which I was very happy to see. I'm going to pull the left bank valve cover off tonight and check everything as well. I figured I may as well since I ordered a new set of gaskets.
If you know the torque specs for the 1970 428 CJ I would appreciate it. If not I will research. I used my old 390 notes from when I built mine for the 65 I had that I replaced the I6 300 for. I figured it's better than just cranking em' down and flying from there.
Thank you for your input. It really helped to get me thinking a little more and motivated me to actually pull the valve cover. Sounds silly but 10 years ago I would have jumped right into it and probably would have pulled the whole top end off thinking the worst.
As for torque, the 428, with the standard rocker shaft stuff, should be the exact same thing as the 390.
For whatever reason, my trusty old Motor's Truck Repair Manual includes the 1969 428 (for the Ranchero?), which shows 40-45 ft/lbs for the rocker shaft support bolts, just like every other FE it lists.
Thanks
Thanks Krewat. It has hydraulics. No adjustment.
I'm going to pull the left bank valve cover off tonight and make sure it's squared away. I did 42 ft/lbs. on the right bank so hopefully it won't decide to loosen up again. One thing that really made me feel good was how clean it was and plenty of oil where it should be.
When I rebuilt the 390 for my 65 It was so gunked up I was afraid I had bought a POS and I was told by the mechanic that FE's are notorious for building up sludge. Bottom line, it turned out to be a great engine and it never let me down.
BTW, any idea why rocker shaft bolts would loosen like that? I'm sure if I had been stupid enough to drive it like that for any distance something bad would have happened.
Definitely check the other side too. Great job!
Think I will get the Zinc additive as well. Is there a particular brand that is recommended?
