silly air intrusion question
Old Jul 5, 2010 | 07:24 PM
clackmaster's Avatar
clackmaster
sorry to everyone just trying to figure this trucks problem out. does the return line end close to the bottom of the fuel tank, so it keeps pressure or is it ok if there is air pockets in it? because mine seems to not hold a solid pressure and it never stays primed but is my trian of thought off base?
Old Jul 5, 2010 | 08:42 PM
LCAM-01XA's Avatar
LCAM-01XA
The return line ends a few inches above the bottom of the fuel tank, it has this silly rubber valve-cap-thing at the end that should prevents air from being sucked in when the engine is off. I see no issues with extending the line till it reaches the bottom of the tank, this way it's always covered in fuel and no air will go in even if the silly rubber thing don't seal quite as good as it should...
Old Jul 6, 2010 | 01:46 AM
Festus Hagen's Avatar
Festus Hagen
Methanoholic
What do you mean it never stays primed??
If you pull the fuel filter after it's been setting all day or overnight is it full or half full??
-Enjoy
fh : )_~
Old Jul 6, 2010 | 08:06 AM
clackmaster
i mean the return line never stays primed, the other end between the lift pump is allways at pressure, im just trying to figure this trucks miss/ raw fuel smell in the exhaust, with the plume of grey smoke
Old Jul 6, 2010 | 01:47 PM
LCAM-01XA's Avatar
LCAM-01XA
Sounds like the timing is too retarded. The return lines will only cause a no-start issue, once the truck is running they may **** fuel if they got a leak somewhere but they will not cause raw fuel smell in the exhaust or excessive smoke...
Old Jul 6, 2010 | 02:45 PM
Festus Hagen
Methanoholic
Does it start right up and stay running???
-Enjoy
fh : )_~
Old Jul 6, 2010 | 03:14 PM
Truck_Girl04's Avatar
Truck_Girl04
I might not be helpful, but if its blowing black smoke change the oil it help with my truck. Also if you having trouble starting it, it could be the return lines have a crack and sucking in air or the glow plugs are gone this happen with my truck
raptor2005
Sep 9, 2013 10:43 AM
wrd0225
May 13, 2013 03:10 PM
richdawg
19
Apr 25, 2012 10:54 AM
dag
15
Dec 7, 2005 01:18 PM
VespaJay
13
Sep 7, 2002 11:57 AM
