tune up woes
Old Jul 5, 2010 | 08:19 AM
dwcranger's Avatar
dwcranger
tune up woes
Hey guys I feel like a fool. I have a 96 150 5.0 with 125k miles on it. Just bought it and thought I would do a tune up. I replaced the cap, rotor plugs and wires. When I started it up it is making a popping noise and running very rough. I double checked and I have the firing order correct. When I shut it off it makes a hissing sound like something is leaking down. It ran good before with only a mild hesistation. Any help would be greatly appreciated.
Thanks,David
Actually it's not a hissing sound. It is a buzzing sound coming from beside where the coil is located. I can lay my hand on top of the connectors there and feel it vibrating a little.
Old Jul 5, 2010 | 08:23 AM
zxwut?'s Avatar
zxwut?
Check the vacuum lines. I bet you have a leak. The red vacuum lines are the worst.
Old Jul 5, 2010 | 08:34 AM
Conanski's Avatar
Conanski
Firing order is 13726548, distributor turns counter clockwise, #1 cylinder is front passenger side, and the cylinder count goes passenger side front to back and then drivers side front to back.
coachkiss
Mar 15, 2014 10:30 AM
Slawdog2006
Modular V8 (4.6L, 5.4L)
Apr 7, 2013 03:18 PM
Showpanther
Dec 30, 2012 08:46 PM
madtom
Dec 14, 2009 07:10 PM
390Highboy
13
Dec 9, 2007 12:14 PM
