A ? FOR SCS OWNERS
Old Jul 5, 2010 | 05:52 AM
miottimouse's Avatar
miottimouse
A ? FOR SCS OWNERS
GOOD DAY THE NEW 79 F350 SCS THAT I JUST GOT BROKE SOME SPRINGS ON THE D/S DRUM BRAKE AND SCREWED THE DRUM [METAL ON METAL] AND NOW THE HUNT IS ON TO FIND 2 NEW ONES I WENT TO THE LOCAL NAPA STORE AND ORDERED 2 DRUMS FOR A 1979 F350 OVER 5300 GVW REAR AXLE [DANA 70] AND RECEIVED DRUMS FOR 3X12 BRAKE SHOES WITCH IS RIGHT BUT THEY ARE NOT NEARLY DEEP ENOUGH THE DRUMS I HAVE ARE 7" FROM THE BOTTOM OF THE DRUM TO THE TOP WHERE THE WHEEL MATES AS IT SEEMS THERE IS QUITE AND OFFSET THE NEW ONES I GOT ARE ONLY 5" DO THESE TRUCKS USE A DRUM FOR DUEL WHEELS? IF SO DOES ANY ONE HAVE A NAPA PART #? THANK YOU REGURDS JOE
Old Jul 5, 2010 | 12:28 PM
79 f350ts's Avatar
79 f350ts
dont knpw if this helps, but to the best of my knowledge they came with dually axles and single wheels. Number dummy would be a big help here as he's been in parts forever and maybe can help with numbers
Old Jul 5, 2010 | 03:38 PM
miottimouse
SO YOU MUST HAVE THE DEEP DRUMS ALSO? IS THIS THE STANDARD AXLE? DULLY WIDTH WITH SINGLE WHEELS IS THIS DUE TO THE FRAME BEING NARROWER WITH THESE TRUCKS?
Old Jul 5, 2010 | 07:04 PM
79 f350ts's Avatar
79 f350ts
i believe so. from what ive read,been told the scs was basically built on the cab/chassis frame which was dual, with a special made bed. any body correct me if im wrong, but im pretty sure on this
Old Jul 5, 2010 | 11:45 PM
HillbillyDeluxe81's Avatar
HillbillyDeluxe81
Actually, all F-350 2wd trucks are built on a chassis-cab style frame....... with the longer wheel base, narrow rear section and DRW axle. The SCS trucks just had a wheelbase that was extended a few inches more. There is really nothing mechanical about the SCS that does not also apply to NON SCS trucks.
Basically, ALL 2wd F-350's use the same drums. So, if you got the wrong drums....it's because they are for the wrong truck entirely. Sounds like you may have gotten some drums for an 80+..... which used SRW drums.
Old Jul 6, 2010 | 12:18 AM
Kalve's Avatar
Kalve
Ok but why did Ford not just make dual wheels fit these trucks? An on a F250 did they come with single or dual axles an could you make these trucks duallys using a axle say from a F350 from 73-79 Ford truck?
Old Jul 6, 2010 | 04:58 AM
NumberDummy's Avatar
NumberDummy
Ford Parts Specialist
Originally Posted by miottimouse
GOOD DAY THE NEW 79 F350 SCS THAT I JUST GOT BROKE SOME SPRINGS ON THE D/S DRUM BRAKE AND SCREWED THE DRUM [METAL ON METAL] AND NOW THE HUNT IS ON TO FIND 2 NEW ONES.
I WENT TO THE LOCAL NAPA STORE AND ORDERED 2 DRUMS FOR A 1979 F350 OVER 5300 GVW REAR AXLE [DANA 70] AND RECEIVED DRUMS FOR 3X12 BRAKE SHOES WHICH IS RIGHT, BUT THEY ARE NOT NEARLY DEEP ENOUGH.
THE DRUMS I HAVE ARE 7" FROM THE BOTTOM OF THE DRUM TO THE TOP WHERE THE WHEEL MATES AS IT SEEMS THERE IS QUITE AN OFFSET.
THE NEW ONES I GOT ARE ONLY 5" DO THESE TRUCKS USE A DRUM FOR DUAL WHEELS? IF SO DOES ANY ONE HAVE A NAPA PART #?
There is no such thing as an F350 Super Camper Special after 1976. After 1976, there are just Camper Special's, as Ford dropped Super from the name after 1976.
Is this truck a Regular or a Super Cab? I assume it's a 2WD, since it has 12" x 3" rear brake shoes.
Originally Posted by HillbillyDeluxe81
Basically all 2wd F350's use the same drums.
No, they do not...as the OP has found out. And what the heck is a DRW axle?
There is no such thing. All 1967/84 F350's w/SRW or DRW (except 4WD) use a Dana 70 rear axle.
The axle is the same SRW/DRW, the difference when DRW's are present are the wheels, hubs and studs.
1971/78 F350 Regular Cab & 1979 F350 Regular Cab 2WD before production date 9/18/1978:
2) D1TZ1126D .. Right/Left Rear Brake Drum.
1979 F350 Regular Cab 2WD from production date 9/18/1978 & some 1980/84 F350 Regular Cab 2WD:
E4TZ1113C (replaced D8TZ1113A) .. RIGHT Rear Hub & Drum Assy.
E4TZ1114B (replaced D8TZ1114A) .. LEFT Rear Hub & Drum Assy.
1978/79 F350 SUPER Cab 2WD:
D8TZ1113C .. RIGHT Rear Hub & Brake Drum Assy.
D8TZ1114B .. LEFT Rear Hub & Brake Drum Assy.
Kalve: Ford did not offer an F250 with DRW until 1985.
Old Jul 6, 2010 | 06:23 AM
miottimouse
hi bill thanks for the info as allways great info yes it is a 4x2 140"wb reg cab with the pass side box spare tire carrier so there was no special name for these trucks other than camper special after 76? strange! took those #s to the napa dealer in town and he will cross ref them and see it we cam find those drums one thing that i find differnt on this axle is the shock mount is ubolted on with the sway bar attathed differnt from my s/c it is welded on finding out more and more about this truck every day regurds joe
Old Jul 6, 2010 | 06:44 AM
NumberDummy
Whoever wrote this jazz you read, didn't know scheiss from shinola.
1973/76 F350 Super Camper Special / 1973/79 Regular Cab Trailer Special / 1977/79 F350 Regular Cab Camper Special were not built on the Cab & Chassis frame.
These trucks were built on the specific to them only 140" wheelbase frame.
There was no such thing as a factory DRW pickup until 1980. All previous F350's with DRW were sold as a Cab & Chassis only. And, Ford didn't offer an F250 w/DRW until 1985.
Old Jul 6, 2010 | 05:06 PM
miottimouse
WALAA!! GOT MY DRUMS THIS MORN NAPA PART #440-1120 3X12 SHOES 7" HIGH FROM THE BASE TO THE WHEEL MATEING SURFACE GOT IT ALL BACK TOGETHER PUTS ME THROUGHT THE WINDSHEILD NOW!! JUST A NOTE NAPA PART # 440-1250 IS THE 5" HIGH DRUMS THANKS A BUNCH EVERY ONE FOR YOUR HELP!! REGURDS JOE
Old Jul 6, 2010 | 08:16 PM
79 f350ts's Avatar
79 f350ts
glad to hear you got her going. Also thanks NumberDummy for for clearing up some confusing and often debated issues. learning more about my truck daily and your presence here is always helpful, thanx
Old Jul 6, 2010 | 09:47 PM
benmoderow's Avatar
benmoderow
The knowledge that oozes from bill is absolutly amazing!! Not to hijack a thread but I'm searching for the rocker moulding for my 76 scs. It can be either the kind that goes on the very bottom of the bed, or the kind that is the thin strip that follows the contour of the bottom body line (sorry i don't know the technical names). I suppose noone reproduces them and I highly doubt there are any collecting dust on someone's shelves.....but any help would be greatly appreciated bill!
Old Jul 7, 2010 | 09:49 AM
NumberDummy
1973/79 F350 140" Wheelbase Lower Bodyside (Bed) Mouldings
Originally Posted by benmoderow
I'm searching for the rocker = lower bodyside "ribbed" bed mouldings for my 1976 Super Camper Special.
The following fit 1973/79 F350's on the 140" wheelbase only (Edit: These are not the Race Track mouldings first offered in 1977 on XLT''s and in 1978 on Lariats).
1973/76 F350 Super Camper Special / 1973/79 F350 Regular Cab Trailer Special / 1977/79 F350 Regular Cab Camper Special / Ford dropped Super from the name after 1976.
Lower bodyside (bed) mouldings in front of the rear wheels:
D3TZ9929076G .. Right Front Lower Bodyside Moulding ~ On Spare Tire Door / Obsolete
No Ford Dealer or obsolete parts vendor has any.
D3TZ9929076F .. Right Front Lower Bodyside Moulding ~ Short Moulding behind Spare Tire Door / Obsolete
D3TZ9929077A .. Left Front Lower Body Moulding / Obsolete
ED BENNETT FORD PARTS in Lebanon PA has ONE = 727-272-8762.
Lower bodyside (bed) mouldings behind the rear wheels:
D3TZ9929314A .. Right Rear Lower Bodyside Moulding / Obsolete
BOWMAN SALES & SERVICE in Bowman ND has ONE = 701-523-3257.
JST AUTOMOTIVE in Lebanon TN has ONE = 615-443-3086.
GREEN SALES CO. in Cincinnati OH has SIX = 800-543-4959.
D3TZ9929315A .. Left Rear Lower Bodyside Moulding / Obsolete
JST AUTOMOTIVE has ONE.
MILLER OBSOLETE PARTS in Binghamton NY has ONE = 800-546-7278.
GREEN SALES CO. has TWO.
WESLEY OBSOLETE PARTS in Liberty KY has TWO = 606-787-5293.
Old Jul 7, 2010 | 06:34 PM
benmoderow's Avatar
benmoderow
WOW! Thanks Bill! I will be checking into those, and now I have the part numbers so people know what I'm talking about. Thanks again!
Old Jul 7, 2010 | 07:15 PM
76f350spercamprspeal's Avatar
Bill, YOU Have Been around LONGER than I have!!!!
What is wrong with you...? He said he has a SCS, Which Mean's "Super Camper Special" if it's an SCS, it's obviously NOT a Super Cab or a 4x4. As these only came in 2WD and Regular Cab F-350, Single Rear Wheel. You even acknowledged it was a F-350 Camper Special and you still had the nerve to ask that goofy question... Ford Dropped The "Super" off of Camper Special after '76 So buyer's wouldn't believe they were getting a Super-Cab Camper Special, Which Super Cabs came out two years prior, in '74. So Super Camper Specials, Became F-350 Camper Specials.
miottimouse, Joe, I'll post your pictures of the truck for you in here.
Also, When you type in all caps, it means your yelling, and your more likely to be ignored. I know your frustrated...
