Turbocharged 4.9L 300
Old Dec 18, 2013 | 07:20 AM
  #211
MisterCMK's Avatar
MisterCMK
What are you using to tune the pcm?
Old Dec 18, 2013 | 08:03 AM
  #212
mcpaul05's Avatar
mcpaul05
I was using SCT but switched to quarter horse and binary editor.
Old Dec 18, 2013 | 10:21 AM
  #213
MisterCMK's Avatar
MisterCMK
Good choice.
Old Dec 18, 2013 | 01:35 PM
  #214
Jarryd's Avatar
Jarryd
Without reading the whole thread, are you using a maf for tuning?
Old Dec 18, 2013 | 06:52 PM
  #215
mcpaul05's Avatar
mcpaul05
yes this is a MAF conversion
Old Dec 19, 2013 | 03:41 AM
  #216
Krisverde's Avatar
Krisverde
Ever thought about megasquirt?
Old Dec 19, 2013 | 06:10 AM
  #217
MisterCMK's Avatar
MisterCMK
How big of injectors are you using?
Old Dec 19, 2013 | 06:11 AM
  #218
Jarryd's Avatar
Jarryd
That's probably the route I'd go. I really want a project like this but can't afford the down time on my dd.
Old Dec 29, 2013 | 08:25 AM
  #219
mcpaul05's Avatar
mcpaul05
I am using 42lbs injectors. The reason I didn't go megasquirt is because I didn't want to spend the money on a stand alone trans controller. Using Quarterhorse and a factory computer has made it a lot easier. The learning curve is steep but once I got the injector slopes right and a good MAF transfer the truck was up and running. I have some small tweaks to make for better drivability before I can really get in to it and work on better MPG. Not worried about the power. I know I will have more then what I got on the dyno last time just because this tune will be a lot better. Also here is a quick video of it running.
Old Apr 12, 2015 | 07:46 PM
  #220
WhiteRhino26's Avatar
WhiteRhino26
Any news on the build?? I am very curious to see how things have turned out. I am going to be building a 300 I6 for my new project and was wondering if you had finished all of the upgrades you had mentioned......
Old Apr 12, 2015 | 07:53 PM
  #221
WhiteRhino26
great build.
Great job!! This is now the route in taking on my 93 crew cab build.
Old Dec 12, 2015 | 11:46 PM
  #222
deerefarmer4's Avatar
deerefarmer4
Turbo on my I6
I'm thinking about putting a turbo on my F-150 and I was wonder what the best parts to use would be. If y'all could help me out that would be great I need to get a project started
Old Dec 13, 2015 | 09:47 AM
  #223
UNTAMND's Avatar
UNTAMND
You should start from page 1. There is a lot of info here.
You need to read about turbo systems and familiarize yourself with how they work.
With that info, your question almost answers itself.
You'll need a turbo.... I'd say use a 5.9 cummins for a quick spool or a powerstroke turbo from a superduty (.84 exh housing)
You'll need a wastegate. I'd use a 38-44mm
Intercooler... A lot of people use them, some people tune around the extra heat.
Exhaust.... Should be as big as you can fit after the turbo.
I'd suggest using dual 2.25 before the turbo to keep velocity up, and if you have a non stock engine, 2.5 before the turbo then into a Y before the turbo.
You'll need supporting mods like fuel system and injectors, and some way to tune it. Quarterhorse, tweecer, or megasquirt. Read about them all.
Maybe a maf conversion if you're not already.
Keep reading on the subject. There's a lot to learn.
Old Feb 4, 2018 | 05:55 PM
  #224
Deries's Avatar
Deries
Plans
I have a 1989 f-150 xlt lariat with the 4.9l straight 6, 2 wheel drive with the four speed with the overdrive. I' planning on turbocharging it but I want to know what I need to do on a stock engine, intake manifold and exhaust manifold bolt torque standards for a rig with a turbo, I have a turbo kit but don' want to mess up my engine. Last do I need a computer to run my turbo or not
Old Feb 4, 2018 | 06:01 PM
  #225
Deries's Avatar
Deries
Plans
