Turbocharged 4.9L 300
#136
Hey, Mcpaul... had a question about why you decided to tune the stock ECU? Did you flash it and start from scratch? Why not megasquirt? Or Redline?
Another thing, how much more power difference do you think you could have gained with the stock cam?
#137
The relay kit is from Dorale its not an adjustable one and you can get it from the same people that I bought the fans from. I didn't have to fab any mounts they are mounted using plastic things that go through the radiator. I dont have any pictures yet and can't take any right now everything is pulled out. but when i get it back together i will update pics of the whole set up it looks alot different now.
As far as why did i stay stock ECM well for one i have an E4OD trans and didnt want to try to make an aftermarket computer run it or do a piggy back system. Plus i like to be different and prove that things can be done. Right now im just using an SCT chip with a couple different tunes on it. Once i get it dialed in i will just use a moates chip with a switch for low and high boost settings.
Its nice to see other people giving it a try. i know it took me a year of research and about two years of building. the only reason it has takin this long is because of my job. i hope to have the truck running by this weekend or next and as soon as i do i promise to have video of it up on youtube.
#138
Have you had any issues with the fans? Some people have been saying cheap = you get what you pay for... They say those cheap fans are prone to catch on fire. I personally don't know as i have never used electric fans for an aftermarket upgrade.
But i totally understand. I'm still debating on asking the college to fund the project, than i can have a larger budget $.
Cant wait to see the video. I wanna see this thing in action and just hear it wine as it revs. What all exhaust wise have you done?
#139
I have the same fans on both my suburban and truck and have not had a problem with them Procomp fans are great. I'm sure some of the really cheap ones people might have problems with but I havent had any.
As far as exhaust goes i have it straight piped from the motor to the turbo no cats or muffler. then from the turbo back is just straight pipe. the truck really isnt that loud since the exhaust has to go through the turbo. before i did have the exhaust running through cats before the turbo but decided to take them out since they were original and didnt want to have to mess with them.
#141
mcpaul05, I went out to a friend of mines house last weekend. I forgot his girlfriend has a 6.5L Chevy so I went and checked it out. The turbo only had exhaust from one bank running to it, the other side was going straight out. Just thought I'd post that up. Thats why they sound like a gasser when they rev I guess.
I wasn't sure if you were joking but just so no one gets it twisted ALL of the 4 6.5 td's I've owned (94,94,95,99) had the dr side crossing under the engine/trans into the pass side and up through the turbine. I've never seen a hemi-turbo 6.5 TD. I would love to see how this worked and how doing the exhaust on all of mine I somehow missed it.
#143
2JZ-GTE would b worth it a little... But i still think the 300 has much more potential that it in the long run. We are puttin out 50 less tq stock and granted we may not have the hp it puts out.. who cares.. these trucks shouldnt go over 140 anyways if even that hahaha. But with a single turbo mod and some tuning we alrdy top the 2JZ all day long off the line. Just a tid bit lol, Also JZ is a toyota.. they are built as toys.. not monsters such as fords
#144
#145
Got the motor back together doing break in now. i have some pics that i plan on posting after the game today and i should have a quick video it up this coming week.
As far as 2JZ motor is concerned while they are great motors and you can do some amazing things with them I think I can build my 300 to be more bullet proof. With a tune just good enough to get it running and at 10.8lbs of boost it makes 300hp and 500tq at the flywheel. Even if I turn up the boost I might not get the HP just because of the head design but I know I can make alot more TQ and in a truck that is shaped like a box that is what counts. With the TQ numbers that I will be making I might just be able to out run a supra. I will find out for sure after I get it retuned. I have a few people I know from work and other forums that have some fast supras and I will put it to the test. I think the only thing that will hurt me is that its a truck shaped like a box. So with that being said I think its enough talk about other cars and motors that are not F150s or 4.9l sixs.
#147
I put pics up on my cardomain page its easier plus I put alittle description of what has been done. http://www.cardomain.com/ride/214722...lar-cab/page-2
#150
