IS IT TIGHT ENOUGH
Old Jul 1, 2010 | 06:57 PM
firebug's Avatar
firebug
IS IT TIGHT ENOUGH
I just put in a new HPOP and the instructions I had from Rubberduck on here said torque was about 160 ft/lbs on the 18 mm bolt that holds on the gear. Well I set my torque wrench for 150 ft/lbs. but it never clicked, instead I noticed I was turning the crank, so would that be considered tight enough ?
Old Jul 1, 2010 | 07:45 PM
427 fordman's Avatar
427 fordman
I put a breaker bar on the crank bolt and it wedged against the frame, then tightened as much as I could. I didn't use a torque wrench, but you need to get it tighter than just once the motor turns. I used rubberducks torque specs too,
Old Jul 2, 2010 | 09:05 AM
97-psd's Avatar
97-psd
yeah, you need to get it tighter, like 427 forman said, wedge the crank bolt to keep it from turning and then re-torque the hpop bolt to proper spec
Old Jul 2, 2010 | 10:23 AM
RubberDuck's Avatar
RubberDuck
The real torque spec is much lower, read to the end of the thread for the real spec. FYI.
Tim put real specs up check them out.
Old Jul 2, 2010 | 02:02 PM
strokin'_tatsch's Avatar
strokin'_tatsch
I always tighten it til the engine turns over then give it a good hard pull about 3 times and call it good. i don't wedge the crank or anything. So yes, it needs to be a fuzz tighter.
Old Jul 2, 2010 | 02:49 PM
firebug's Avatar
firebug
Whatever you do DON"Ttry to torque to 160, at 120 my bolt snapped the head off
I went to the dealer and talked to a friend who is a mechanic there and we looked it up in the book. The torque for the 18mm bolt is 95 ft/lbs. Luckily we were able to get the old one out without any damage to the new pump.
Old Jul 2, 2010 | 03:54 PM
strokin'_tatsch
i think that might be why the duck told ya the torque spec is actually much lower... Glad y'all got it out though. Hows the pump workin'?
Old Jul 2, 2010 | 05:09 PM
RubberDuck's Avatar
RubberDuck
Dam I wish we could have caught you earlier. But glad you got the bolt out. This happened before, and it got heated for no reason. Yes, it's a writeup, but I did say "I think" and stated I didn't know the real torque spec. And the real specs have been at the end of the thread for a long time. But I'm sorry you broke the bolt, and glad you got it out without problems. I tried to edit the post a long time ago, but could not. Again I'm sorry for any trouble.
RacinNdrummin
52
Dec 9, 2016 11:24 AM
jnm0510
1997 - 2003 F150
Mar 17, 2013 09:59 AM
fdude64
Jan 30, 2011 10:10 PM
btm991
Dec 17, 2009 04:56 PM
RhinoScores
1978 - 1996 Big Bronco
Dec 27, 2006 06:25 AM
