pyro install ?
Old Jul 1, 2010 | 06:38 PM
menmy02x's Avatar
menmy02x
pyro install ?
Getting ready to put the probe in the rear exaust manifold . My question is can i drill and tap at any angle or is there a preferred angle?
TIA Vince
Old Jul 1, 2010 | 07:27 PM
fordpride's Avatar
fordpride
This is driver side rear manifold under the truck
Probe installed
you want to set the tip of the probe in the center of the pipe for best readings
Old Jul 1, 2010 | 08:01 PM
F350-6's Avatar
F350-6
Like the picture shows, somewhere in that general area. You want a place you can easily reach for the drilling and tapping procedure, and you want to stay clear of access to the bolts in case you need to remove your up-pipes for some reason down the road.
Old Jul 1, 2010 | 09:15 PM
Tom S's Avatar
Tom S
Being fairly square to the part makes starting threads easier.
Old Jul 9, 2010 | 11:34 PM
aawlberninf350's Avatar
aawlberninf350
It's a Van Gogh
My 2 cents:
I tapped the threads into my manifold pretty far up the tap, on the theory a larger circumference would provide a stronger thread for the pyro. Since then I've decided a smaller hole (same tap) would be better for 2 reasons.
One, a smaller hole will allow less of the fitting into the exhaust flow. Small difference perhaps, but why block flow unnecessarily?
Second, years down the road that pyro might need replacement, and if the hole is rusted out or chewed up it may be possible to tap it just a bit bigger with the same tap. Beats opening it up for a 1/4 inch pyro.
And yeah, sometimes I just stare up at the bottom of a car or truck for too darn long.
richsoucie
Mar 3, 2009 10:15 AM
randall2051
Jan 26, 2008 08:59 AM
countryF150
May 10, 2006 11:28 AM
greghoffmann
Jul 27, 2001 06:14 PM
Brady
Jan 7, 2000 08:25 PM
